Distributor Service/Maintenance?
Old May 3, 2004 | 10:01 PM
vteec's Avatar
Default Distributor Service/Maintenance?
Hi,
I am sure you can help me guys.
Can you please tell me what kind of service or maintenance i should do to my distributor?
Sometimes i read about rotors etc.... but are these changes cause the car is bot running well or just servicing ?
I have changed all fluids etc.... since it got shipped from Japan but i have never touched the distributor.
Regards,
Old May 4, 2004 | 04:38 AM
00MRSi's Avatar
Default Re: Distributor Service/Maintenance? (vteec)
Replace dist. cap and rotor, inspect/change wires and plugs. Tune-up items. Not expensive..
Old May 4, 2004 | 08:50 AM
typer_801's Avatar
Default Re: Distributor Service/Maintenance? (00MRSi)
Make sure the rotor screw is in tight after replacing. The cause of most ITR distributor failures is because that rotor screw gets loose and destroys the internals.
Old May 4, 2004 | 09:10 AM
vteec's Avatar
Ok thanks a lot guys.
As usual to ht ppl !
Rgds,
Old May 4, 2004 | 11:59 AM
Justin Klemgold's Avatar
Don't overtighten the bolts on the distributor...they are fragile and snap easily...
<-----knows all too well about how fragile they are.
Old May 4, 2004 | 12:26 PM
Chris N's Avatar
Default Re: (Justin Klemgold)
I just changed my cap and rotor (and fuel filter), but did not see anything in the maintenance schedule in the owner's manual. Anyone know what interval they should be replaced?
chris - who still needs new oem plugs/wires.
Old May 4, 2004 | 12:32 PM
Opie's Avatar
Default Re: (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">chris - who still needs new oem plugs/wires.</TD></TR></TABLE>
Len hooked me up last week Just installed new oem wires, cap, rotor and screw, valve cover gasket and finally removed all the msd stuff that I was using
yangkm
Feb 26, 2011 04:20 PM
carblegal
Oct 26, 2006 03:28 PM
Truman001
May 30, 2006 06:07 PM
vtec_crazy
Jan 19, 2005 12:39 PM
DCtwoR
Aug 8, 2002 01:34 PM
