Which turbos will work for the DRAG manifold and downpipe???
Old Nov 3, 2001 | 01:58 PM
zojirushi's Avatar
Default Which turbos will work for the DRAG manifold and downpipe???
Which turobs will work for the DRAG manifold and downpipe, other than the T3/T4?? I just wanna know my options, thanks.
Old Nov 3, 2001 | 02:01 PM
zojirushi's Avatar
Default Re: Which turbos will work for the DRAG manifold and downpipe??? (zojirushi)
Will a T3 from a 300zx work?????? I need to know asap, thanks
Old Nov 3, 2001 | 02:09 PM
Seraph0's Avatar
Any T3 turbine housing'ed turbo will work. NOt sure if the 300ZX uses the standard T3 casting. If not, you *should* be able to pick up a housing cheap that will be usablewith your T3 center section.
Old Nov 3, 2001 | 02:15 PM
zojirushi's Avatar
Default Re: Which turbos will work for the DRAG manifold and downpipe??? (MarkC)
word, thanks for the quick reply
Old Nov 3, 2001 | 02:16 PM
zojirushi's Avatar
Can a T28 fit??
Old Nov 3, 2001 | 02:39 PM
DLB1994's Avatar
nope
Old Nov 3, 2001 | 02:40 PM
zojirushi's Avatar
Default Re: Which turbos will work for the DRAG manifold and downpipe??? (DLB1994)
DOH
Old Nov 3, 2001 | 02:42 PM
DLB1994's Avatar
a saab t3 turbo will work
Old Nov 3, 2001 | 02:47 PM
zojirushi's Avatar
aight koo
those saab turbos are mad cheap right??? Where could I find a good used one?
Old Nov 3, 2001 | 03:07 PM
DLB1994's Avatar
get one from a like a 1986 or so saab the one in the 1990's are oil&water cooled older ones are just oiled cooled thats what u want they have a ex housing if a .48 and a compressor of .42 it may start choking up around 9 or 10psi In to u upgrade the compressor to a 60 trim the stock wastegate is set for 5 or 6psi make sure u get a intercooler for that small turbo is going to throw out some heat
back to the turbo u can get one from a junk yard just rebulid it or get a brand new Cartridge they on ebay.com right now for $105.00 and turbo city got rebuild kits to
mengy007
Apr 4, 2007 09:57 AM
EJ8 GSR-T
Feb 13, 2006 08:04 PM
j-bird
Nov 21, 2004 03:45 PM
lucas569
Aug 7, 2001 08:53 PM
