violent shaking on acceleration
Old May 3, 2004 | 09:41 PM
LB CRX's Avatar
Default violent shaking on acceleration
seems like i havent posted for years. the questions are getting hella technical from you guys. my question would belong in the beginers forum if they had one. anyways
my sister has a 94 accord. when im driving the car, it shakes. its almost as if the wheels are going to fall off. first the prob started on the freeway in gears 3-5 (only on acceleration). now it happens from gears 1-5 (again only on acceleration). at first i thought the tires were unbalanced and the car needed alignment. but i fixed that, and found it wasnt the case.
the only other idea i had was that one of the engine mounts might be cracked or worn out, but when i took it to the mechanic he indirectly called me an idiot. i dont know, maybe i am. what do you guys think is the matter with the car?
TIA
Old May 3, 2004 | 10:42 PM
Seedc2's Avatar
Default Re: violent shaking on acceleration (LB CRX)
what did the mechanic discover to indirectly call you an idiot?
did you ever confirm your engine mounts were okay?
Old May 3, 2004 | 11:27 PM
poison's Avatar
Sounds like the motor mount bushings are shot -- possibly the driver side and/or the rear mount.
Look at 'em and check the condition -- oh and call the mechanic dude a dumbass, and go somewhere else.
Old May 4, 2004 | 12:16 AM
LB CRX's Avatar
Default Re: violent shaking on acceleration (kendogg)
well the mechanic rolled his eyes and looked at the other mechanic and said "he said it was the motor mounts" in a smart *** way. but whatever, i can do the work myself.
about the motor mounts, i suspected it was it, but i couldnt really tell just by looking at them. i was too lazy to try to take em out, but i guess i have no other option now. thanks for the help guys
Old May 4, 2004 | 06:36 AM
JimBlake's Avatar
So after he rolled his eyes at the other guy, did he actually CHECK your engine mounts??
You don't have to take them out, but you can grab the valve cover & try to shake the engine. There's supposed to be some flex in the mounts, but the engine shouldn't bang around or hit something.
How about drive axles? Either the inner or outer CV joints can get real loose, that can cause shaking on acceleration.
Maybe the engine's misfiring under load? Spark plugs & tune-up stuff?
Paul 631
Jan 5, 2013 07:18 AM
Bad_dude
Aug 8, 2010 02:41 PM
shewit08
18
Jun 21, 2010 05:34 PM
enerlevel
Jan 20, 2008 09:24 PM
James
Jun 27, 2005 07:29 AM
