JDM B18c1 GS-R (sir-G)
the jdm gsr motor should just say B18c on it. if it says b18c1 its a usdm motor. if you want to safely run your motor in that chasis you would need to get it BAR certified. your gonna have to make sure all the emmissions are correct and need to run a usdm gsr ecu also/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 »</TD></TR><TR><TD CLASS="quote">u would need a cfk sensor if you people in cali do an obd test</TD></TR></TABLE>
thats only for obdII
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet »</TD></TR><TR><TD CLASS="quote">you need to convert to obdI, and run gsr emissions, nothing needs to be replaced on the motor itself but you will need to use a usdm gsr ecu.</TD></TR></TABLE>
Ricky Ng
May 18, 2019 07:23 PM
