Car hesitates real bad when I press gas.
Well, my motor was running fine for awhile, it felt a little slow on bottom end but when vtec hit it was fine, I had a TPS cel so I assumed it was that. last week I installed a vafc and things went to ****.
it hesitated really really bad, barely got to 25 mph and limped it home from my friends where I installed it.
I re-wired it, cut the map sensor wire which I didn't do the first time, hooked it up and it ran, but it still hesitated a little bit, but when I got to 4500 rpm it just let go and pulled real hard. but anything under that it hesitates real bad. Today I took the VAFC out and it was doing the same thing
idle is normal, No Codes, new O2 sensor, good TPS sensor, map sensor seems fine. it's not the ecu. and timing is fine. just when I press the gas it barely revs up, like something is really holding it back
there is black soot splatter out the exhaust, and an oil leak near vtec solenoid. those are the only abnormal things.
good luck on finding the solution...i have been trying to figure that out for a while now...there are a few good threads on this hesitation problem
...there are a bunch of suggestions in those threads on what the problem could be and the probable solution...
Fuel filter is new, I just replaced the plugs, map sensor, TPS, and O2 sensors are ok. so I was leaning towards spark plug wires and rotor.
but last time my rotor went out my car wouldn't start at all.
I want to borrow someones wires and rotor before I go out and spend money on them and realize it doesn't fix my problem.
Also when I searched I couldn't really find an answer.
Try checking your injectors....try a fuel injector/fuel system cleaner along with high test fuel.....I use to get black splatters and smoke when my teg was outta time but u say urs in in correct time...usually hesitation comes from too much fuel or not enough....check everything fuel related....
the black **** from the exhaust is usually from running rich. Do that complete tune up you have planned... then afterwards.... Properly Reset the ECU then let it idle for the proper time to recalibrate the AIR/Fuel ratio. Then shut it off and start it back up. Good Luck
Also, is your VAFC adding a **** ton of fuel at low RPM ? you didnt mention how you had your VAFC set
What is your Fuel Pressure set at
I mentioned up top that I eventually took the VAFC out.
The thing that doesn't make sense is that it ran fine before I messed with the vafc. a little rich from the Mugen chip, but other than that it was just fine.
All I did with the VAFC was I wired it wrong at first, it bogged out really bad, I could barely drive it.
then I wired it right, and it was ok, but it still hesitates a lot. Now I wired everything back up to stock and it does the same thing, hesitates when I hit the gas.
I changed out, O2 sensor, TPS, spark plugs, map sensor is good and it's got a new fuel filter.
so now I'm just going to try wires and rotor, and anythign else people suggest
I'm running a PR3 on a fresh built motor, GSR block, itr head.
it shouldn't need Seafoam yet. Also, I did try an LS ECU and the effect didn't change, still hesitates real bad. very slow revving
ahh fresh motor .. ok .. well maybe still have distributor problems? i have one of my own .. but i was reading about this guy with an ITR 9k miles his was hesitating and it ended up being his ignitor i believe ... do you have another distributor to swap just to test ?
Nope, no extra distributor for right now. I thought it'd be less headache to stay with Non-obd, and I guess I was kinda wrong about that.
at an idle, when I press the gas the motor revs up really slow, at half throttle it revs up to 3k when it should have gotten up to about 4 in the same time. make sense?
