BOGGING on first crank?? running rich on high rpm?!?! O2 sensor???
Old May 3, 2004 | 07:27 PM
TegBen's Avatar
Default BOGGING on first crank?? running rich on high rpm?!?! O2 sensor???
hi, basically as the title says. .
If I let the engine cool down and crank it after a while, the car will bog out. On high rpms it smells/runs rich . . . . is this due to the o2 sensor being bad? I no longer have a cat, (2.5 all the way back). If not the o2 sensor, any other suggestions?
Thanks in advance
Old May 3, 2004 | 08:29 PM
TegBen's Avatar
bump
Old May 4, 2004 | 09:44 AM
TegBen's Avatar
bump agian
Old May 4, 2004 | 09:53 AM
HUBB's Avatar
Default Re: (HHB 2185)
thats weird....im having similar problems....if i start my car up and let it idle and shut it off, then try to start it back up a second later, it will have problems turning over.....dont know whats up with that....
Old May 4, 2004 | 09:54 AM
HUBB's Avatar
Default Re: BOGGING on first crank?? running rich on high rpm?!?! O2 sensor??? (HHB 2185)
btw im running a jdm b18c-r with a p28 chipped ECU....thinkin im like u and runnin too rich...i had a 02 sensor code thrown and im thinkin that could be it too...were probably on the same boat..
Old May 4, 2004 | 06:25 PM
TegBen's Avatar
hmm maybe so , but my bogging is on the first crank in the morning, our after letting it cool off and only on the first crank . . after a second or two of giving a little gas, it goes away .. weird. Anyone else?
Old May 6, 2004 | 12:17 AM
WeaponR
Guest
Posts: n/a
I had a similar problem. The easiest way to tell if its your o2 sensor is to disconect it and go for a drive. The car will run off pre-determined maps, and they aren't bad at all. You will get a check-engine light, but at least you will know that the o2 sensor is bad if you disconnect it and it stops bogging.
Modified by WeaponR at 7:52 PM 5/6/2004
Old May 6, 2004 | 05:05 AM
Jimmy's Avatar
Global Moderator
Default Re: (WeaponR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeaponR &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem. The easiest way to tell if its your o2 sensor is to disconect it and go for a drive. The car will run off pre-determined maps, and they aren't bad at all. You will get a check-engine light, but at least you will know that the o2 sensor is bad. </TD></TR></TABLE>
What He said.
livedew12
Jan 10, 2012 08:58 PM
ffspiel
Engine Management and Tuning
12
May 19, 2009 11:45 AM
ffspiel
Apr 6, 2009 05:14 PM
ATS*Mark
Apr 7, 2004 07:06 AM
spencedogg
27
Nov 20, 2003 04:20 PM
