Which spark plugs for my GSR-T
Old May 3, 2004 | 06:59 PM
patdemps's Avatar
Default Which spark plugs for my GSR-T
I need to get some spark plugs tomorrow for my car. Which ones would be the best for a turbo gsr.
If someone could provide a part # too that would be greatly appreciated. I appreciate the help
how much should i gap them?
Old May 3, 2004 | 07:07 PM
Turboteggy's Avatar
Default Re: Which spark plugs for my GSR-T (patdemps)
NGK BCPR7ES
I gap mine at around .030" depends on how much boost you gonna run. Less gap for more boost.
Old May 3, 2004 | 07:10 PM
TheShodan's Avatar
Moderator
Exactly. part # 2975
Old May 3, 2004 | 07:18 PM
TRE_'s Avatar
Default Re: (TheShodan)
i alway's used 7e's as the other guys mentioned. gapped around .30-.32
Old May 3, 2004 | 07:20 PM
D@nnY's Avatar
NGK part number 3330s ...
Old May 3, 2004 | 07:25 PM
FlamingEJ20's Avatar
Default Re: (D@nnY)
bkr7e 's...NGK that is
Old May 3, 2004 | 07:28 PM
Rory Breaker's Avatar
Default Re: (FlamingEJ20)
I run BKR7E's as well...3330.
Youll find most people here run the BKR or BCP's.
Old May 3, 2004 | 07:31 PM
PrecisionH23a's Avatar
Default Re: (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">I run BKR7E's as well...3330.
3330's are bcp's not bkr's sucka!
Old May 3, 2004 | 07:33 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlamingEJ20 &raquo;</TD></TR><TR><TD CLASS="quote">bkr7e 's...NGK that is </TD></TR></TABLE>
gapped .028
Old May 3, 2004 | 07:52 PM
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
3330's are bcp's not bkr's sucka!</TD></TR></TABLE>
My baaaaaaaad...then help a brotha out and tell me what the BKR7E's are?
Nevermind, theyre 6097's
I always mix the 2!
Old May 3, 2004 | 08:08 PM
patdemps's Avatar
Default Re: Which spark plugs for my GSR-T (Turboteggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy &raquo;</TD></TR><TR><TD CLASS="quote">NGK BCPR7ES
I gap mine at around .030" depends on how much boost you gonna run. Less gap for more boost.</TD></TR></TABLE>
Ill be running 7.5psi.
What would you guys suggest I gap them at considering that, I plan on around 250whp +/-....conservative tune.
thanks for all the help thus far
Old May 4, 2004 | 04:46 AM
92HB_HB's Avatar
what if i'm running about 15 psi and up?? which plugs should i shoot for then??
Old May 4, 2004 | 05:32 AM
Default Re: Which spark plugs for my GSR-T (92HB_HB)
I ran 3330's on 20psi of boost gapped to .025 with 425whp. Most of you B series guys should be fine with a .026-.028 gap with 15psi of boost.
I believe some people have gotten away with 500whp using these.
Old May 4, 2004 | 05:35 AM
fipracing_com's Avatar
NGK Iridiums, have a fine electrode and are perfect for a boosted app.
Old May 4, 2004 | 05:40 AM
BOOSTIN1's Avatar
Default Re: Which spark plugs for my GSR-T (PrecisionH23a)
none of you guys run 9 series. like the 5238's
Old May 23, 2004 | 08:51 PM
choytim's Avatar
Default Re: Which spark plugs for my GSR-T (PBOOSTIN)
Where to buy these plugs? Anyone have a set for sale?
Old May 23, 2004 | 08:54 PM
TheShodan's Avatar
Moderator
That heat range is actually too cold. EGTs drop too low, and run tons too rich. You've got to run a LOT of boost to warrant using 2 steps colder like that. I mean RACE APPLICATIONS
Old May 24, 2004 | 08:06 AM
sky88's Avatar
bkr 8 e iriway is very very good from ngk
Old May 24, 2004 | 08:08 AM
rollydc69's Avatar
I run 5238's gapped to .020 at 15 psi.
Old May 24, 2004 | 11:03 PM
DRIVENRacing's Avatar
zex spark plugs... of da hooooooook 10 psi
Old May 25, 2004 | 01:12 AM
Charles B.'s Avatar
Default Re: (TurboHybridEG6)
bkr7e's here at .030
Old May 25, 2004 | 01:14 AM
GSRrR's Avatar
Default Re: Which spark plugs for my GSR-T (choytim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choytim &raquo;</TD></TR><TR><TD CLASS="quote">Where to buy these plugs? Anyone have a set for sale?</TD></TR></TABLE>
got mine from pitcrew. couldn't find it at pepboys, kragens, autozone....
i use the bcpr
edit: think i remember reading they had em at napa. you can give em a call.
Modified by GSRrR at 6:00 AM 5/25/2004
Old May 25, 2004 | 04:54 AM
patdemps's Avatar
Default Re: Which spark plugs for my GSR-T (GSRrR)
i just ordered mine from advanced auto. they didn't have them in stock but overnight delivery got them there the next day for an easy pickup.
NGK BCPR7ES is what I am using. at a .30 gap.
Old May 25, 2004 | 06:08 AM
boosted_dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboHybridEG6 &raquo;</TD></TR><TR><TD CLASS="quote">zex spark plugs... of da hooooooook 10 psi
nOOOOOOO!!!!!! dont use those, there bad.
Landon
OneCrzySetup
Nov 17, 2006 11:53 AM
Phatch99
Sep 8, 2005 12:39 PM
TuRbO_CrX_7o2
Feb 1, 2004 05:28 AM
Big Josh
Dec 16, 2003 10:26 PM
gdrum
Oct 27, 2003 05:48 AM
