Is it the clutch & flywheel not mating properly???
Old May 3, 2004 | 06:23 PM
JdmAcclude's Avatar
Default Is it the clutch & flywheel not mating properly???
I have an Exedy baseline Racing Clutch w/ stock flywheel in ride. I noticed today that when I changed into 2nd or 3rd, and stepped on the gas alittle hard...the engine seemed to rev but I wasn't really accelerating. It took a bit for my car's speed to catch up with the RPM's...if that makes sense. If I tried to shift hard (chirp) in second, the engine would just rev without strong torque to the wheels. Any thoughts. I think I need a new flywheel. Perhaps the ACT Streelite.
Old May 4, 2004 | 03:36 AM
HAccord96's Avatar
Default Re: Is it the clutch & flywheel not mating properly??? (JdmAcclude)
Sounds to me like a slipping clutch or leaking master cylinder.
Old May 4, 2004 | 04:23 AM
KGAccord's Avatar
Default Re: Is it the clutch & flywheel not mating properly??? (HAccord96)
^werd...what he said
Old May 4, 2004 | 09:25 PM
JdmAcclude's Avatar
My clutch resivoir is full. I think the clutch is slipping. When I did my swap, I had to resurface the flywheel. It probably needs to go. If I change out the flywheel, do ya'll think I need a new clutch too? Its only 8 months old. Exedy.
Old May 4, 2004 | 11:22 PM
HAccord96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmAcclude &raquo;</TD></TR><TR><TD CLASS="quote">My clutch resivoir is full. I think the clutch is slipping. When I did my swap, I had to resurface the flywheel. It probably needs to go. If I change out the flywheel, do ya'll think I need a new clutch too? Its only 8 months old. Exedy.</TD></TR></TABLE>
Just bleed your clutch line and see if it gets better or stops the problem. When you resurface the flywheel, usually it should make the flywheel more balanced and work better, not worse. Let us know if bleeding it works if you decide to do so.
Old May 6, 2004 | 06:51 AM
LeMoN_GrAsS's Avatar
how do you bleed your clutch line???
Old May 6, 2004 | 12:03 PM
HAccord96's Avatar
Default Re: (LeMoN_GrAsS)
If you are lookin at your motor from the front, the slave cylinder is on the transmission as you look down, to the left of the header. It has a bleeder valve on it. It is 8mm. Use a open socket wrench to loosen it to bleed it.
rich7777
Jan 3, 2011 03:21 PM
Lauj87
Sep 17, 2005 06:32 PM
punkkazzjoe
Sep 25, 2004 09:49 AM
J337_UNIT
Jul 25, 2003 10:03 PM
