comptech gsr filter
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Yes, it should. I had one until I replaced the OEM box with the Ice Box. You reuse the rubber gasket and the rubber tip on the end of the OEM filter. So don't toss your old filter until you get these parts off of it, per the Comptech instructions. (which you can download off the Comptech website)
There's a large round rubber gasket on the end of the OE filter. The part that connects to the intkake arm. It is used as a seal for the intake box around the large neck area on the end of the filter [that goes to the intake arm].
Sorry for the late reply. I've been swamped at work and I can't post at work. Read only! Crap!
Good luck!
Good luck!
eaglclon
Honda S2000
Nov 28, 2005 10:40 AM
Honda.F1
May 15, 2004 03:27 PM
EricUSC
Jun 8, 2003 08:48 PM
