Searched not the info I need.... tach dead
Old May 3, 2004 | 04:20 PM
IS3Fifty's Avatar
Default Searched not the info I need.... tach dead
I know why its not working. Let me give specs first
-93 Civic CX
-96 B18c
-EG6 gauge cluster
I know that on an OBD2 motor the tach is somewhere in the distributor, but what wire/pinout do I need to tap to get my tach in gear? Also, where do I make the connection with the tach, meaning where on the tach will I need to tap FROM?
So basically, what I am looking for is a Where-to diagram.
Old May 3, 2004 | 09:51 PM
IS3Fifty's Avatar
Default Re: Searched not the info I need.... tach dead (TODAeg6)
come on someone has to know there **** about this....
Old May 12, 2004 | 11:51 AM
SuzukaBlueAP2's Avatar
Chris...
I dunno what ECU you are going to end up using...but, if you got an OBDI engine harness, and used an OBDI ecu, I think it would save you some headache.
If you want though, I do have the ECU pin outs at home and also what wire on teh dizzy is for a tach reading.
shocked to see a straight answer from me?
Old May 14, 2004 | 05:39 PM
IS3Fifty's Avatar
Default Re: Searched not the info I need.... tach dead (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">Chris...
shocked to see a straight answer from me? </TD></TR></TABLE>
Yeah, actually. Im almost postive that it is a blue wire on the dizzy plug. I am running an OBD1 ecu... SO know knock is cancelled. Vtec and PS is wired. just need to figure out the damn tach.
Old May 14, 2004 | 10:20 PM
hatchi's Avatar
look at the driverside tower harness. On there there's wire that doesnt go anywhere blue colored. connect a wire to that to the dist and you're good to go
young geezer
Jul 16, 2007 06:46 AM
b_serious
12
May 11, 2006 04:26 PM
AErrorist
Apr 22, 2006 03:34 PM
SOHC_MShue
Aug 10, 2005 02:07 PM
ITRswapandslow
Jan 7, 2004 03:20 PM
