Help! Going to take a batt to my H22-a4!
Old May 3, 2004 | 02:40 PM
forcedaccord95's Avatar
Default Help! Going to take a batt to my H22-a4!
ok guys!
i have searched and did everything possible to make this peice of **** work! im basically going to start fresh and retrace my steps!
i have a 95 honda accord (odb1). i put a 2001 h22a4 (Odb2) in my car. im using a p13 out of a 92-95 prelude.
heard that the distributor had to be a out of a 92-95 prelude along with the injectors? is this true. if so who wants to sell them?would this cause the car to idle like **** and throw a egr code 12
ok i need to wire in the AIB, please help in details with a step by step install. i know it needs to go to pin A17.
i wired in the knock sensor, got rid of that code,which is pin number D3, good to go
i switched pin number's A6 and A11, which are egr and heater O2 senser wire, car ran great for a day, now its thowing a EGR code 12, could it be the EGR silenoid or the EGR valve, is there a way to test the EGR valve itself? does anyone have a 92-95 EGR forsale?
WILL THE EGR FROM MY F22-B1 WORK? ARE THEY THE SAME?
replaced the 02 senser, brand new!
have a vafc , its on stock settings!
car is and ex, so it have the vtec silenoid (pin A4)in and the vtec pressure switch Pin D6 already!
how do you check to see if an injector is bad?
please e-mail me at snave24@netscape.net if you have any of thr following?
92-95 distributor
92-95 injectors
92-95 egr silenoid assembly (controls vacum)
92-95 Egr valve
PLEASE HELP!
newquimc
Jun 24, 2013 11:49 PM
vvtli78k
Jun 30, 2008 06:24 PM
s2000 mf
Oct 30, 2004 06:37 PM
4x4dakota
Aug 11, 2004 03:30 AM
Malgerus
Sep 3, 2002 10:09 PM
