Wireing for auto -> manual help.
Old May 3, 2004 | 02:39 PM
SkRiBLaH's Avatar
Default Wireing for auto -> manual help.
ok, this is all the information i have:
What you need to do is cut the plug from the auto shifter assembly, and leave about 5 inches of wire.
There are two really fat wires. This is so that you can start the car. You will need to connect these two together. Or what you can do is, run these wires to the switch on the clutch pedal assembly.
Then there is a black wire you will need to connect to a green wire with a white stripe. This puts the car in “park” so you can take the key out. Now you can also hook this up to the other switch on the clutch pedal, but remember everytime you want to take your key out, you have to press the clutch.
Finally, you need to find out what plug you used on the engine wiring harness to hook up to your reverse sensor on the manual transmission.
Find out what colors they are, and find the colors on one of the ECU plugs. You should find it at the ECU plug that has all of the auto tranny sensors. A multimeter helps a lot because there are multiple colors.
Run these two wires to the yellow wire and a green wire with black stripe at the big plug that you cut off from the auto shifter. Now your reverse lights should work.
Hopefully this made it easier on you, and not confused you.
well i am confused. seeing as i am doing this on a 92-95 civic.
anyone who has done this know the wireing?
hondaon18's
29
Jul 9, 2010 10:26 AM
frost_0ne
Oct 28, 2008 05:32 PM
ej2 coupe
13
Oct 17, 2007 11:29 AM
alexsracing
Oct 9, 2005 08:22 AM
getnasty
29
Feb 23, 2005 07:09 AM
