EG and EK shock... Compatible?
Old May 3, 2004 | 02:23 PM
endlessdv's Avatar
Default EG and EK shock... Compatible?
I got a good deal on some 96-00 Shocks but I own a EG. are the EK and EG shocks compatible?
Old May 3, 2004 | 02:29 PM
HyBriDcxR's Avatar
Default Re: EG and EK shock... Compatible? (siamturbo)
Yeah you can use those shocks. But if you ever decide to upgrade your lca it won't fit.
Old May 3, 2004 | 02:53 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: EG and EK shock... Compatible? (HyBriDcxR)
with some modifications they can be campatible.
Old May 3, 2004 | 02:56 PM
slammed_93_hatch's Avatar
dude you should really search Emerika has covered this topic, and just the other day there was a topic about it.
Old May 3, 2004 | 03:00 PM
Civiclx's Avatar
here are the options
96 up rear shock on 92-95 rear lca ->ground down the bushing
92-95 rear shock on 96 up rear lca ->use wahsers on each side of the inside bottom of the shock (like all tokico rear civic shocks on 96 up)
Old May 3, 2004 | 03:04 PM
Black HB's Avatar
Default Re: EG and EK shock... Compatible? (Civiclx)
Im using EK Teins SS on my EG, I was going to just cut the bushing down to size but found lca's that had 40mm bushings that fit the EG.
blarue09
May 18, 2010 03:50 PM
ej1serge
Sep 19, 2009 12:32 AM
Jlamar757
Suspension & Brakes
Apr 6, 2006 08:33 PM
vizsual00
May 14, 2004 06:50 AM
Breeze
Aug 11, 2003 11:25 PM
