painting a plastic lip
Old May 3, 2004 | 12:19 PM
deviant1's Avatar
Default painting a plastic lip
do you need to primer a plastic lip b4 painting it? or just sand and paint?
Old May 3, 2004 | 03:51 PM
deviant1's Avatar
Default Re: painting a plastic lip (deviant1)
Old May 4, 2004 | 10:57 AM
deviant1's Avatar
one mo
Old May 4, 2004 | 11:40 AM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
just painted my mugen one last night. i dont plan on putting it on soon, but i just sanded. i'll let u know how that works out
Old May 4, 2004 | 07:59 PM
deviant1's Avatar
Default Re: painting a plastic lip (DrunkeNmonk)
bump
Old May 4, 2004 | 08:01 PM
The_Todd's Avatar
Farts in the shower
Painted mine today...
I cleaned it then sanded it down 400 and 600 grit.
Primed and black paint.
I might clear coat it, but I don't want it shiny
Old May 11, 2004 | 08:38 PM
deviant1's Avatar
Default Re: painting a plastic lip (VRDrvr)
i sanded mine with 600 grit sand paper then primered it. i then wet sanded it with 600 again. i painted it flat black and it looks streaky. like you can tell where i sanded it. anyone know how to make it look smoother? should i re-sand the whole thing or maybe more coats of color?
Old May 11, 2004 | 08:45 PM
* B A N N E D *
resand it all down smooth. then reaaply color, then wetsand with 1000 grit. then again with 2000, then use rubbing compound, then wax it like crazy. meguiars cleaner wax works wonders
Old May 11, 2004 | 09:09 PM
RickyGoshDarn's Avatar
If its painted and in good shape or if hasn't been painted just
1. Get some water and soap and clean it real good
2. Alcohol it
3. Get some Adhesive sealant like Bullfrog or something so the paint will stick
4. Spray that on let it set for awhile then your ready to paint
(But if the paint is pealing or its hacked up yea sand it down then primer it up)
Old May 11, 2004 | 09:33 PM
deviant1's Avatar
Default Re: painting a plastic lip (CrxWolf)
its been sanded, primered, sanded, and painted. you can see the sanding marks slightly. if i resand it with a higher grit above 600, do i need to re-primer it and then color it? or just color?
Old May 11, 2004 | 10:00 PM
* B A N N E D *
no need for primer. primer is for bare metal anyways
Zaraki
Paint and Body
May 21, 2008 03:24 PM
deeweezy187
Mar 8, 2006 06:29 PM
BAYgasDC2
Aug 19, 2005 02:29 PM
alfaaay
Oct 20, 2003 07:12 PM
Briman2021
Mar 4, 2003 10:38 PM
