4th gen corner lights: replacing the bulbs
I just have the stock corner lights, but need to replace the bulbs in both, opened the hood saw the one connection, undid the screw but the covers still will not come out. Am i missing something. Again i just want to replace the bulbs.. any help
If you unscrewed at the top, reach with fingers back to where the grommet meets the fender, and yank forward.
There is a ball and socket compression fitting that holds those bad boys in place. (look closely you might be able to see it) Then, twist lamp assembly to remove from the back of the housing.
phoenix_iii
Aug 8, 2008 11:54 AM
