What octane for 18 degress timing on a D16A6?
I just picked up a new crx and the guy bumped up the timing to 18 which was just confirmed by checking the timing myself.
Is it safe to use 87 octane? I've been using 89 without a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenEg6 »</TD></TR><TR><TD CLASS="quote">Dennis if it pings bump it up to 91 otherwise it dont matter. </TD></TR></TABLE>
What he said ^^^^
What he said ^^^^
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX »</TD></TR><TR><TD CLASS="quote">i also have a cam for that motor, check my sig, its in classifeds
A cam with more overlap than stock actually reduces the actual compression ration by bleeding off compression, thats why radical cams need higher compression pistoms to work well
</TD></TR></TABLE>A cam with more overlap than stock actually reduces the actual compression ration by bleeding off compression, thats why radical cams need higher compression pistoms to work well
yeah thats true, i was going to put in d16a1 pistons but forget it lol, im not gonna spend the time and money on it, im ready to swap motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">I have my ZC set to 18* and I fill up on 87 and it is fine.</TD></TR></TABLE>
ditto
ditto
Azn Kenny
Jan 31, 2006 06:11 PM
BlackCRX
21
Oct 16, 2002 01:42 PM
