road race/autocross suspension setups
Old May 3, 2004 | 06:59 AM
temp's Avatar
Default road race/autocross suspension setups
calling all auto-x'ers/road racers
could you list your suspension setups?!?!?!? i am curious to see what you guys are running
Old May 3, 2004 | 07:49 AM
APEX CRX's Avatar
Default Re: road race/autocross suspension setups (temp)
here's my low buck setup (until I can afford better) for my HPDE/open track CRX
GC sleeves with 375lb spring rates all around
Tokico Illumina's
Stock front sway bar
Suspension technique 22mm rear adj. sway bar
Function 7 rear lower control arms
Prothane bushings all around
numerous strut braces from Z speed and Em racing
Autopower roll cage
Old May 3, 2004 | 08:48 AM
SiRex91's Avatar
Default Re: road race/autocross suspension setups (APEX CRX)
Here's my setup for HPDE/Open Track
Koni Adjustables (a.k.a. "yellows")
KG/mm mystery springs (soon to be replaced with custom rate GC's w/ GC upper mounts)
Energy Suspension bushing kit
OBX front upper strut brace (soon to be replaced with custom fab'd solid brace)
Skunk2 rear lower brace
Kirk Racing 4point roll cage
OEM Si sway bars
Tenzo RNR copies 15x6.5
Falken Azenis 205/50/15
Modified by SiRex91 at 1:11 PM 5/3/2004
Old May 3, 2004 | 09:04 AM
temp's Avatar
thanks guys.....keep em comin
Old May 3, 2004 | 09:13 AM
96-EJ6 B18C's Avatar
Default Re: (temp)
Here's my autoX setup...
Stock 14's wrapped with falken 502's inflated to 45 psi up front and 35 psi out back
lowered on suspension techniques springs
stock struts
stock sways
no idea what the alignment looks like...
and I still whoop *** on cars that I shouldn't
Eventually I will be putting on a set of H&R Race springs over a set of Koni yellows and have some beefier sways, as well as Rota 15's and a set of azenis...but that is a ways away so I just making do with this set up for now and learning how to drive.
Old May 3, 2004 | 09:34 AM
tommycrx's Avatar
Default Setup
Eibach Pros
Tokico adjustables
ST sways, front and rear (most don't do the front)
Neuspeed tower braces, front and rear
Autopower 4-pt rollbar (stiffened up things surprisingly well)
15" SSR Type X's w/ Azenis
Pretty typical autox setup. I would recommend a Quaife LSD as well.
Old May 3, 2004 | 09:39 AM
temp's Avatar
Default Re: Setup (tommycrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommycrx &raquo;</TD></TR><TR><TD CLASS="quote">Eibach Pros
Tokico adjustables
Pretty typical autox setup. I would recommend a Quaife LSD as well.</TD></TR></TABLE>
yeah i am going to get a Quaife LSD and an ATS FD
Old May 3, 2004 | 09:41 AM
Tokico adjustables
What do you think of the ST sways?
T S R Performance's Avatar
Default Re: Setup (temp)
tokico blues...skunk 2 coilovers. sucks on the bumps but awesome in turns . yeah LSD is good too
Old May 3, 2004 | 09:59 AM
tommycrx's Avatar
Default Re: Setup (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">What do you think of the ST sways?</TD></TR></TABLE>
I like 'em a lot; was my first real suspension mod. Had 'em on the crx for at least 4 years now without problems.
Since so many people are so adamant about not doing the front one, though, I'd talk to others who don't have the front installed, and get their opinions.
Old May 3, 2004 | 10:03 AM
Since so many people are so adamant about not doing the front one, though, I'd talk to others who don't have the front installed, and get their opinions. </TD></TR></TABLE>
Cool thanks for the info...I need to get more suspension stuff done to my rex...there is a mustang at the track with my name on it.
Old May 3, 2004 | 11:59 AM
spaceman's Avatar
ya dood smoke that stang...im buildng my crx for road racing..i got skunk2's and some strut bars...looking for my stuff when i get $
Old May 3, 2004 | 12:11 PM
Default Re: Setup (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">ya dood smoke that stang...im buildng my crx for road racing..</TD></TR></TABLE>
Hella...Good luck with the road racing...that is eventually what I would like to do too.
Old May 3, 2004 | 12:18 PM
pumpkinkidd's Avatar
just curious, what kind of motor setup do you guys have road/race
Old May 3, 2004 | 12:28 PM
Simon Tibbett's Avatar
I have right now only Tokico Illumina struts and H&R springs, I like the way it feels.
Old May 3, 2004 | 06:58 PM
STS_Underdog's Avatar
I've got my 91 Si set up for STS. I'm running:
Koni single adjustables w/ front brake line holder removed for extra travel
ST rear 7/8 bar, no front
Neuspeed front upper strut tower brace (more to come as $ allows)
ES suspension bushings, motor mounts, trans, and trailing arms
No name coilovers- came with the spring rates I was looking for, 400 f, 450r
15x7 Kosei K1's until I can afford Enkei RPF01's
Falken Azenis
Front and rear camber adjustment (front en route from JZR)
Cornerweighted
Old May 3, 2004 | 07:09 PM
EG8R's Avatar
Default Re: road race/autocross suspension setups (STS_Underdog)
Car: 1991 DX hatchback
Spoon ITR yellows with the blue progressive coils
Spoon front and rear upper strut bars
ES master bushing kit, ES rear trailing arm bushings, ES 88 rear lower bushings
Si rear sway bar
14" steelies with Falken Azenis set to 35psi
Next suspension related mod: 92-93 GSR front sway bar.
Old May 3, 2004 | 07:15 PM
Rostr02's Avatar
I am going to order my KW Varient 3. I race my friends ls civic hatch with ground controls and koni adjustables, damn car rides like a gocart. I will keep everyone posted on my $1700 KW investment.
Old May 3, 2004 | 07:25 PM
hyperlite1080's Avatar
Heres what i got
Skunk 2 coil overs and springs
KYB AGX 4 way adjustable struts
Front Strut bar
Suspension Techniques Polyurethane Bushings all around
Suspension Techniques Sway bar
Falken Azenis 195/60/14r
I keep my times close to the Mazda Miata's, and sometimes beat them.
Grr Wolfe
47
Jul 13, 2006 01:50 AM
TorganFM
Oct 13, 2003 08:54 PM
thehatchninja
10
Dec 23, 2002 12:08 AM
TurboInteg95
Jun 24, 2002 08:53 AM
ArchAngel Sabastian
Dec 11, 2001 04:17 PM
