Walbro Fuel Pump Help. * Experts Only Plz *
Well, I have everything in placed wired and mounted, but the fuel pickup line that plugs into the bottom of the pump that runs inside the tank, the hose continiously comes off, I just wanted to know how you all went about strapping that hose to the pump. Thanks
Walbro 255lph
Walbro 255lph
are you serious?
a clamp.
p.s. the bottem of the pump should have a pickup screen, not a hose, the only hose, goes between the pump and 'mounting' piece of the pump, for fuel to get pumped through, no fuel is picked up by a hose.
a clamp.
you see, this is why i asked for experts only
The pump is ran inline, therefore the " screen " that we in the real world call a fuel filter is inside the tank, while the pump is outside the tank. I cant use a clamp because there is only a peice of plastic about 1/4 of an inch to work with coming out of the pump
Yes,, I guess...
anyway, im still stumped on how to securly attach the hose. Will a glue work? along with a clamp of course. Ive tried using a small clamp, but ti comes off and I dont want to try going with just a clamp, im sure it will pop off under the pressure of the pump
eh, i ended up just dremling some plastic away and using an uber clamp..However, the pump itself leaks, It leaks through the electical connectors...
wtf? am i missing a washer or something?
why didn't you just call me..I have install alot of these..and I have one on tweak as well.....all you need to is ask grasshopper. I am always here.
lostforawhile
Welding / Fabrication
19
Mar 12, 2011 10:18 AM
