Aftermarket pistons but not rods??
Old May 2, 2004 | 11:46 PM
Slimm-rw-'s Avatar
I'm a Jackass
Default Aftermarket pistons but not rods??
I have a set of JE 9.1 pistons that I may put in an lsvtec to boost, but its definitely gonna be a budget build. How much boost or how much HP can be supported with stock rods? Or is it even worth it?
Old May 2, 2004 | 11:58 PM
PIC Performance's Avatar
Default Re: Aftermarket pistons but not rods?? (Slimm-rw-)
From what I've read, stock pistons and rods are good for up to roughly 250whp it looks like. I don't think I'd go very far past that mark, even with forged pistons, because your entire engine is only gonna be as strong as its weakest component, which in this case would be the still-stock rods.
Old May 3, 2004 | 01:03 AM
FOrSfEd's Avatar
Why not just buy some eagel rods. If your gonna be building I would wait until you could also get the rods.
Old May 3, 2004 | 04:24 AM
GDM Z28's Avatar
Default Re: Aftermarket pistons but not rods?? (Noob4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noob4life &raquo;</TD></TR><TR><TD CLASS="quote">From what I've read, stock pistons and rods are good for up to roughly 250whp it looks like. I don't think I'd go very far past that mark, even with forged pistons, because your entire engine is only gonna be as strong as its weakest component, which in this case would be the still-stock rods. </TD></TR></TABLE>
250hp? now that i fixed all my leaks i should be putting down 300-320whp @ 13 psi on my stock ls. hell if it blows, a block is $100-$200
Old May 3, 2004 | 08:44 AM
99B16Si's Avatar
i just did 305whp, 210wtq on a stock gsr with wiseco pistons on 12-13psi and im sure itll last a while. if i were u tho id definitely do the arp rod bolt upgrade for the LS rods and possibly shotpeen them
Old May 3, 2004 | 10:13 AM
-iLLuZioN-B18C1's Avatar
Default Re: Aftermarket pistons but not rods?? (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">Why not just buy some eagel rods. If your gonna be building I would wait until you could also get the rods.</TD></TR></TABLE>
id do the same. you got some nice pistons. the first thing to go will be your rods, it almost makes no sence to me to buy one without the other. like forsfed said, go with at least some eagles.
Old May 3, 2004 | 11:52 AM
Default Re: Aftermarket pistons but not rods?? (civicflnum1)
good luck man!
Old May 3, 2004 | 01:06 PM
SiRex91's Avatar
Not worth it. Since you're on a budget just go for some Eagle rods and add a bunch of boost. Stock rods
99black_em1
May 16, 2011 06:45 AM
turbo-crx
Apr 18, 2008 09:08 AM
crexer
Oct 4, 2003 06:28 AM
98civicEX
Aug 19, 2002 02:58 AM
