Stock Type-R valve Train how much HP?
Old May 2, 2004 | 11:37 PM
R-1303's Avatar
Default Stock Type-R valve Train how much HP?
planning to get my motor built in the future, goal is 300-350 whp. I was wondering how much can a stock type R valve train handle?...will my goals for horse power be too much stress on the components?, just needed some info on how i can maybe use the stock valvetrain or maybe change out things like retainers and valve springs.
Thanks.
Old May 3, 2004 | 12:16 AM
FlamingEJ20's Avatar
Default Re: Stock Type-R valve Train how much HP? (R-1303)
depends on how high u wanna rev.
Old May 3, 2004 | 12:36 AM
R-1303's Avatar
Default Re: Stock Type-R valve Train how much HP? (FlamingEJ20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlamingEJ20 &raquo;</TD></TR><TR><TD CLASS="quote">depends on how high u wanna rev.</TD></TR></TABLE>
Full Redline 8600-8800 rpm..don't planning on raising redline too much.
Old May 3, 2004 | 04:13 AM
PM-Performance's Avatar
you will be more than fine . im still on the stock head 100%. and mine has been taking the beating for a while now.
Old May 3, 2004 | 06:30 AM
metal-x's Avatar
Default Re: Stock Type-R valve Train how much HP? (itr206)
you'll be fine with the stock ITR head, just watch your revs
Old May 3, 2004 | 06:34 AM
Default Re: Stock Type-R valve Train how much HP? (metal-x)
even with the revs. i have went out 9k many of times.
Old May 3, 2004 | 06:44 AM
metal-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">even with the revs. i have went out 9k many of times. </TD></TR></TABLE>
do you have ARP head studs?
Old May 3, 2004 | 06:47 AM
I do now , but i didnt before when i was doing those revs.
Old May 3, 2004 | 07:31 PM
R-1303's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">you will be more than fine . im still on the stock head 100%. and mine has been taking the beating for a while now. </TD></TR></TABLE>
I know to get head studs..so its pretty safe to take it up to 8600-8800 rpms and with 300-350 whp? i was afraid the stock ITR heads couldn't handle such a beating?
Old May 3, 2004 | 11:43 PM
R-1303's Avatar
anybody else what to chime in?
Old May 4, 2004 | 05:32 AM
turbotypeR@SPEC's Avatar
25 Year Member
i have been pounding on mine for about three years now.it has taken 9000rpm banging off of the rev limiter with 534whp and no problems yet.i have seen as high as 9300rpm on the recall.on a side note,my last setup had the wastegate lock up and went to 60+psi.cracked all four sleeves,burnt all four pistons,and the valvetrain,head, and head gasket were fine,all with stock head bolts that had been re-used three times.i think the stock head bolts are better than the arp
Old May 4, 2004 | 05:26 PM
R-1303's Avatar
Default Re: Stock Type-R valve Train how much HP? (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">i have been pounding on mine for about three years now.it has taken 9000rpm banging off of the rev limiter with 534whp and no problems yet.i have seen as high as 9300rpm on the recall.on a side note,my last setup had the wastegate lock up and went to 60+psi.cracked all four sleeves,burnt all four pistons,and the valvetrain,head, and head gasket were fine,all with stock head bolts that had been re-used three times.i think the stock head bolts are better than the arp </TD></TR></TABLE>
Thanks!..with this said, and your amount horsepower, i will be confident now in keeping the stock head "stock" valves, porting, etc....and daaam! sorry about your mishap, and congrats on your amount of hp!..i only plan to hit 350 max.
Old May 4, 2004 | 05:33 PM
turbo_ef9's Avatar
woah..
D16SohcVtec
May 14, 2008 08:04 PM
wrestler72
Sep 5, 2007 04:56 PM
Baron55
Sep 20, 2006 09:08 AM
Baron55
Sep 18, 2006 09:38 PM
Junkyard2000
25
Sep 16, 2005 04:33 PM
