just picked up my first crx today!
Old May 2, 2004 | 10:34 PM
TypeRPaul's Avatar
Default just picked up my first crx today!
Well im over from the itr forum to test my hands at a crx, i want it as a commute vehicle and something to look nice for the time being. there are a few crucial problems though, the engine has 200,000 miles on it and it is lobing real bad for some reason, i know im prolly not gonna get that much out of it, but i was curious how much a refurbished stock non vtec engine goes for?( sorry not to familiar with the d series motors) also my drivers side door lock doesnt work for some reason, i havent dove into it yet, but how hard is it to install power locks in the crx? price? thanks again all. btw it was a steal at 400 bucks!
Old May 3, 2004 | 05:20 AM
TypeRPaul's Avatar
no one?
Old May 3, 2004 | 05:24 AM
GreenMachineRex's Avatar
Default Re: (TypeRPaul)
motors are faily cheap $500 or less be my guess. **** power windows/locks.
Old May 3, 2004 | 05:37 AM
SwissChEz82's Avatar
Default Re: just picked up my first crx today! (TypeRPaul)
What do you mean by the lock not working. It doesn't lock at all or can you only lock it with the key from the outside or inside with the door closed?
If you're gonna get another engine and willing to pay 500 go for a ZC.
Old May 3, 2004 | 06:20 AM
TypeRPaul's Avatar
its just a beater for the time being, i probaby just want to dress it up, i have my R in the garage for power, as for the lock it just spins if you put the key in the outside of the drivers door, any sugestions on what it might be? or am i gonna have to change out my door locks?
Old May 3, 2004 | 07:46 AM
1SIKCRX's Avatar
you can find stock D16a6's for $150-$250 with low mileage easily!! i have power door locks and power windows in my crx. door locks are from DEI. and the power windows are SPAL. there easy to install. the directions are good! or you could go get the power door locks and power window assembly from a 4 door civic lx. there's sites out there that have write-ups on it and what you need to get off the donor 4 door civic lx!!
on your lock spinning like that. sounds to me you need to replace it.
Old May 3, 2004 | 08:15 AM
Skinnypunk's Avatar
I would surely go for a ZC if you are needing to swap a new motor in.. around 450-600 depending
Old May 3, 2004 | 08:24 AM
crx_88_si's Avatar
Default Re: (Skinnypunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skinnypunk &raquo;</TD></TR><TR><TD CLASS="quote">I would surely go for a ZC if you are needing to swap a new motor in.. around 450-600 depending</TD></TR></TABLE>
for sure! you'll get a little more pep with very little changes to wiring (move 2 wires from the dist to the exhaust cam)
Old May 3, 2004 | 08:33 AM
2ride4life's Avatar
Default Re: (1SIKCRX)
sorry don't mean to but in, but what search terms did you use for that 4 door lx swap for the locks and windows? can you point me in to some threads?
thanks
Old May 3, 2004 | 09:18 AM
TypeRPaul's Avatar
thanks for all the info all, where is a good place to pick up a low mile d16A6 in not cal? i know i should go with the zc, but its just a beater for now, maybe a b16 later, but would rather spend the extra loot on my R
Old May 3, 2004 | 09:57 AM
T S R Performance's Avatar
you can pick up a stock crx motor for like 400 bucks. ZC can get you for 500 without trans and ecu., but its easy to use knock off parts for the ZC such as a DX trans or Si trans. and you use a PG7 ECU (88-89 Integra) welcome to the CRX club
Old May 3, 2004 | 10:06 AM
NOGAMES's Avatar
GET A B16 CRAZY PERFORMANCE
Old May 3, 2004 | 11:07 AM
B2FiNiTY's Avatar
Default Re: (NOGAMES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOGAMES &raquo;</TD></TR><TR><TD CLASS="quote">GET A B16 CRAZY PERFORMANCE</TD></TR></TABLE>
right...
Anyways, you can always get a d16y7 which basically bolts up and includes very little modifications and they are easier to find with less mileage.
Is yours an Si?
JohnnieChimpo
Oct 5, 2009 07:02 PM
KoDKingVegeta
16
Apr 12, 2009 06:48 PM
crxforum
37
Mar 4, 2006 03:43 AM
^jefs0ng
25
Oct 31, 2003 10:27 AM
model x
Nov 14, 2002 11:06 AM
