Wiring JDM EF fog light switch
OK, I won a JDM switch on ebay....and the pigtails off the harness are:
black, red/black (there's two this color), red/yellow and a red. What connects to what?
Hmmz
Red is power
Black is ground
The two of the same would go to the lights
red/yellow could be power for the light in the switch
I'm just guessing here....
Red is power
Black is ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 »</TD></TR><TR><TD CLASS="quote">Hmmz
Red is power
Black is ground
I'm just guessing here....</TD></TR></TABLE>
Shouldn't I "beef up" the power to the lights by making the two of the same color into one...then running that to a relay?
Red is power
Black is ground
I had to do this the other day. Its actually not how it appears. The black is not ground its actually one of the positives. See the clip looks like this...
The two stacked ones are the positives and the negative is the one that is alone. One way the positives are hooked up will make the light for the switch stay on all the time and if so flip them around and it will be ok.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 »</TD></TR><TR><TD CLASS="quote">OK, I won a JDM switch on ebay....and the pigtails off the harness are:
black, red/black (there's two this color), red/yellow and a red. What connects to what?</TD></TR></TABLE> I just got a set of fogs from E-Bay to,but no switch
. Does any one know where i can find one, or does anyone have one that they want to sell? As for the colors black is ground,the two red blacks are to the lights,the red yellow is the one that goes to the plug on your fues box that has power when you turn on you lights,thw red wire goes to direct power, ther should be a plug on the fues box that has constant power.If your harnes for the lights still has the factory conections it should be plug and play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAND CIVIC »</TD></TR><TR><TD CLASS="quote"> I just got a set of fogs from E-Bay to,but no switch
. Does any one know where i can find one, or does anyone have one that they want to sell?</TD></TR></TABLE>
Just keep re-checking on ebay. I got mine from the user "jhotimports" or something like that. Fast shipping.
. Does any one know where i can find one, or does anyone have one that they want to sell?</TD></TR></TABLE>Just keep re-checking on ebay. I got mine from the user "jhotimports" or something like that. Fast shipping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">i dunno man........the switch i got uses a black wire, a blue wire, a blue white wire, and i think 1 more wire.......i never seen that red ****</TD></TR></TABLE>
back from the dead!
i have the same wires as temp; black, white, white w/ blue stripe. either way, i have no harness so i'm going to have to make my own...black is negative i assume, white positive, white/blue signal to the fogs?
back from the dead!
Just keep re-checking on ebay. I got mine from the user "jhotimports" or something like that. Fast shipping.</TD></TR></TABLE>
hmmm, u mean j_hotexports? good people and good prices, funny how stuff in ga goes to cali and vice versa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">you dont have a jdm foglight switch...you have an EDM rear foglight switch...
I was wonderin b/c my fog switch didn't sound like that.
</TD></TR></TABLE>I was wonderin b/c my fog switch didn't sound like that.
Are you positive? Just great. Now I gotta research for a true front facing fog light switch..or just buy a normal one.
i got the jdm foglights and there is only 2 wires commin off of it with a harness..so probably since it has 4 wires? then 2 from one light and 2 from the othert mayb this might help =p
the front fog lights switch should be a vertical switch that goes in the slots under the steering wheel...the rear foglight switch goes into the cluster cover...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">the front fog lights switch should be a vertical switch that goes in the slots under the steering wheel...the rear foglight switch goes into the cluster cover...</TD></TR></TABLE>
Actually that is what it looks like.
Nisif
Honda CR-V & Element
12
Dec 7, 2024 11:50 PM
8valvesoffury
Feb 12, 2009 10:14 AM
