d16z6 in '88 crx si runnin pm6 ecu
Old May 2, 2004 | 08:41 PM
RABHonda's Avatar
Default d16z6 in '88 crx si runnin pm6 ecu
what would be some suggestions for vtec function?
this engine was just broken in yesterday, last night to be exact, and it is mean.
the build-pm3 .50 over pistons coming out of the cylinder by 1mm, crank shaft micro-polished w/ stock rods, std main/rod bearings, cyinders bored/plateau honed runnin 0.0005 piston-to-cylinder wall clearance. the head is runnin the meanest JG cam, with JG springs, Ti retainers. the IM has been ovaled for better flow, then port-matched to the head. JG TB that has been port matched to the IM. the engine overall is runnin 225psi across the head, each cylinder absolutely perfect.
options for vtec switch; custom fabbing switch operatine off of oil pressure or rpm's, fields vtec controller, swapping over to obd1 harness/ecu, or programming the pm6 ecu.
i suspect when i get vtec working this car will be runnin low 12's.
give me your suggestions, thoughts, and opinions!
thanks.
Old May 2, 2004 | 09:40 PM
CRXracer88's Avatar
swap over to obd1.
Old May 2, 2004 | 09:55 PM
garlic jr's Avatar
Default Re: (CRXracer88)
to hell with obd1 just go with apex or fields...
Old May 3, 2004 | 12:40 AM
SECURITY's Avatar
I too say go obd1 from experience with a PM6. PM6 =
Old May 5, 2004 | 06:06 PM
static_signal's Avatar
Default Re: d16z6 in '88 crx si runnin pm6 ecu (RABHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RABHonda &raquo;</TD></TR><TR><TD CLASS="quote">what would be some suggestions for vtec function?
the build-pm3 .50 over pistons coming out of the cylinder by 1mm, crank shaft micro-polished w/ stock rods, std main/rod bearings, cyinders bored/plateau honed runnin<U> 0.0005 piston-to-cylinder wall clearance. </U>the head is runnin the meanest JG cam, with JG springs, Ti retainers. the IM has been ovaled for better flow, then port-matched to the head. JG TB that has been port matched to the IM. the engine overall is runnin 225psi across the head, each cylinder absolutely perfect.
thanks.</TD></TR></TABLE>
This seems a little to good to be true ... unless your running some type of tool steel for the pistons, that .0005 clearance is gonna be .0000 when the motor gets to temp.. .0000 equals BOOM!
Old May 5, 2004 | 09:43 PM
mr. carpenter's Avatar
Default Re: d16z6 in '88 crx si runnin pm6 ecu (static_signal)
i got an ecu reprogrammed to run it from zdyne
http://www.zdyne.com/
Old May 6, 2004 | 08:35 AM
RABHonda's Avatar
actually, no static. its been a few days now, and after sorting out a lean a/f mixture (fabbed my own adjustable FPR), its still runnin strong and keeping pressure cross the head. problem im having now...i have a leaky valve stem seal to deal with.
like i said in a previous post; you can run a close piston-to-cylinder wall clearance in aluminum engines because of their excellent cooling ability.
Old May 6, 2004 | 08:49 AM
crx_88_si's Avatar
Turbo edit. I believe that they are REALLY close if not already there w/ a 1-wire vtec function similar to ZDyne. I think you have to use a ps9 (90-91 ex) ecu.
Old May 6, 2004 | 10:32 AM
tgreaves's Avatar
Default Re: (crx_88_si)
You could just get a rpm switch from summit racing for like $45 or so..
Old May 6, 2004 | 10:36 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">Turbo edit. I believe that they are REALLY close if not already there w/ a 1-wire vtec function similar to ZDyne. I think you have to use a ps9 (90-91 ex) ecu.</TD></TR></TABLE>
i am with him
just get a VAFC, they go on ebay for under 200
get the PM6 chipped with Turbo edit (same **** as uberdata, hondata, ghetto dyne and all that)
and be happy ... no need for OBD1
Old May 6, 2004 | 10:37 AM
tgreaves's Avatar
Default Re: (USDM 4G VTEC)
TurboEdit
Old May 6, 2004 | 03:16 PM
RABHonda's Avatar
Default Re: (tgreaves)
im gonna chip the pm6 to see how that goes. all i need is a q42 resistor for vtec, and re-chip the ecu for better fuel/timing curves. im just waiting on my burner to come from germany.
matt90
16
Apr 12, 2011 10:20 PM
ww3slayer
Aug 23, 2010 04:28 PM
vegeta420
Dec 23, 2004 05:16 AM
LorenGeist
12
Oct 6, 2004 06:30 AM
11secdx
10
Oct 27, 2002 02:55 PM
