GSR: ATS FINAL DRIVE
Anyone running the ATS final drive on a GSR.. browsing R forum cause various users on there are running the ATS.. but none in integra forum after searching..
Anyone?
Also wondering RPMS at 80 MPH on a GSR tranny?
- trying to find a way to stay under 4400RPMs when cruising.. LS 5th gear?
EDIT* this is the 4.929 final
Modified by Heisdan at 8:57 PM 5/4/2004
Anyone?
This will give you stock GSR gear ratios and can calculate speed at redline in each gear:
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
This doesn't have GSR stock ratios, but you can copy and past them from the first link. It will give you a graph which shows you speed vs rpm in each gear.
http://reverendsgarage.net/ind...r.php
Remember to edit the final drive gear to the ATS FD gear ratio (4.9 i think)
Edit: looks like with a 4.9 Final Drive, in 5th you'll be hitting VTEC (4400rpm) at around 77mph with WOT, and around 84mph with moderate (cruising) throttle.
Install is the same. I don't have a gsr but do have power. The parts are the very much the same. I have an Os Giken myself. Still have to buy the collar first gear and needle bearings. ($110.00) The only way to get around that is if you have a type r tranny because of the size of the collar.
