A/C Compressor question! Please Help!!!!!
Old May 2, 2004 | 02:19 PM
jhiz's Avatar
Default A/C Compressor question! Please Help!!!!!
HI there, I have a 94 civic LX, bone stock. I have a quick question regarding the AC Compressor. The AC Compressor clutch engages fine only when the car is cold and not warmed up. After the car is warmed up and when i switch the AC switch off, and then on again, the clutch will not engage.
Now when the car is warm and the clutch does not engage, I placed 12v directly to the compressor and the clutch engages fine and it blows cold as it should. what could it be? i checked the relay by switching the ac fan relay(same part number according to honda) and it does not engage. the fan works fine with EITHER relay.
ofcourse, with the clutch not engaging the car blows warm air.
btw: when the car is warmed up and I try to turn the AC on (the clutch doesn't engage), I tried to jump the thermo switch right below the relay to see if it would turn on, but still no luck...so it can't be the thermo switch.
please help
Old May 2, 2004 | 02:32 PM
techer's Avatar
Default Re: A/C Compressor question! Please Help!!!!! (jhiz)
could be an intermitant heat induced open circuit. try running a new wire from relay to compressor. also, just in case make sure you have the right thermoswitch.
Old May 2, 2004 | 05:47 PM
jhiz's Avatar
Default Re: A/C Compressor question! Please Help!!!!! (techer)
which wire is the one that goes from the compressor to the relay??? is it the red skinny one? i know i should just open up the wire loom and look for myself, but i thought i would just ask
Old May 3, 2004 | 09:36 AM
techer's Avatar
couldnt tell you off hand, check for the wire that recieves b+ when the clutch engages.
Old Jun 8, 2004 | 05:14 AM
rdmcclung's Avatar
Did you ever figure out the problem? I have a 91 civic that does the same thing and I am trying to fix it.
Thanks,
Bob
alextech
Honda Civic (2006 - 2015)
Mar 27, 2018 10:30 PM
akb427
Honda Civic (2001 - 2005)
Jun 28, 2013 08:51 AM
sk8er602
May 22, 2007 07:25 PM
turbob16ef
Jan 11, 2006 03:47 PM
jhiz
Jun 22, 2004 08:37 AM
