CRX w/ Half Radiator , what crossmember works ?
iv read the post on ht about the half radiator in the crx .. ..but didnt find the info i was looking for .....
i was wondering if anyone knew what crossmember will let the 92-95 civic half radiator fit in the car ...
i know jimfab, place racing make some .. but didnt know if those would allow it .. or if they made more than one crossmember for diff radiators in the crx or what not .. .
if anyone had any info on this . .that would be great .. ..
thanx
thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant »</TD></TR><TR><TD CLASS="quote">Place Racing work one. My friend had it on his turbo CRX b16 setup.</TD></TR></TABLE>
ah .. and place racing only makes only one crossmember for the crx right ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 »</TD></TR><TR><TD CLASS="quote">JIMFABs do not have provisions for a 92-95 Civic radiator!</TD></TR></TABLE>
oh so which should i go with place racing ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Place makes the crossmember that allows you to use a civic/half radiator.
Exactly, but this xmember hangs low and does nothing to improve traction.
</TD></TR></TABLE>Exactly, but this xmember hangs low and does nothing to improve traction.
Exactly, but this xmember hangs low and does nothing to improve traction.</TD></TR></TABLE>
It also almost killed me too, but in full race applications it works good.
almost killed you ?
</TD></TR></TABLE>almost killed you ?
my main reason i am asking about the half radiator is mainly cause i dont want to run into problems when i get the turbo in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera »</TD></TR><TR><TD CLASS="quote">
almost killed you ?</TD></TR></TABLE>
Yeah, that **** broke when I was about to jump on the freeway and my steering got very sloppy, luckily it happened when I was about to get on, so I got off the nearest exit and slowly drove the car home.
Yeah, that **** broke when I was about to jump on the freeway and my steering got very sloppy, luckily it happened when I was about to get on, so I got off the nearest exit and slowly drove the car home. </TD></TR></TABLE>
oh damn .. not sure if i would wana go for that ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 »</TD></TR><TR><TD CLASS="quote">Your Place xmember broke? Where at?</TD></TR></TABLE>
Where the radius rod goes, the passenger side. I didn't have a digicam back then or I would have taken pics.
Where the radius rod goes, the passenger side. I didn't have a digicam back then or I would have taken pics. </TD></TR></TABLE>
hmm ... you think i would be ok fitting in a turbo on my d16 with stock radiator?
not sure if it would be worth the trouble and worriing about something breaking..
if you have access to a welder why not just make your own bracket....
i personally have not heard anything good from the place racing crossmembers
jimfab is the way to go
not sure if it would be worth the trouble and worriing about something breaking.. </TD></TR></TABLE>
They supposedly reinforced it from then on, you might wanna call them.
how long ago did this break in the xmember happen ?
</TD></TR></TABLE>how long ago did this break in the xmember happen ?
We made our own bracket ... with some angle steel a vice and a welder....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraXSi »</TD></TR><TR><TD CLASS="quote">
We made our own bracket ... with some angle steel a vice and a welder.... </TD></TR></TABLE>
cool ..my main concern was the hood ... did you have any troble closing the hood with the jimfab ?
cool ..my main concern was the hood ... did you have any troble closing the hood with the jimfab ?</TD></TR></TABLE>
Nope fits like stock now...
Nope fits like stock now... </TD></TR></TABLE>
nice .. i might consider the jimfab now ... know anyone selling one ? heh ...
the bracket you had to make ... would be the bracket for the top of the radiator to the support correct ?
the bracket you had to make ... would be the bracket for the top of the radiator to the support correct ?</TD></TR></TABLE>
No made a lower bracket and lined it up with the rad. support
