will my car still run with a hondata ecu with no chip???
Old May 2, 2004 | 12:22 PM
boosted_dc2's Avatar
Default will my car still run with a hondata ecu with no chip???
im going to break my engine with stock injectors, so i will be running my stock ecu(p72). my question is can i get it socketed and prepped for hondata but just not put the chip in and not plug the interface box in. i know some jumpers get cut and added so i was wodering if it would still run like stock???
Landon
Old May 2, 2004 | 12:28 PM
POLLO's Avatar
Default Re: will my car still run with a hondata ecu with no chip??? (boosted_dc2)
As long as you have a chip on that socket(stock program) you'll be fine..... Otherwise you car won't run.
Old May 2, 2004 | 12:38 PM
Mad Cow's Avatar
It will run stock if you cut J1.
Old May 2, 2004 | 04:06 PM
Default Re: will my car still run with a hondata ecu with no chip??? (MadCow)
so if i have an open socket, it wont run??? how is that different from stock??? there is no chip in there now (just no socket). will any of the cut jumpers effect it??
thanks
Landon
Old May 2, 2004 | 05:43 PM
poid's Avatar
when you have an open socket, and J1 is jumped you will have a solid CEL and the car will run in limp mode. J1 tells the ECU to run the car from the new socket, instead of the stock location.
All you need to do is cut J1/make sure it isnt jumped and the stock ECU will run, as it wont try and read the open socket.
Old May 2, 2004 | 06:51 PM
Default Re: (poid)
sweet thanks!!!
Landon
Organization
Engine Management and Tuning
20
Sep 11, 2011 03:37 AM
Justin4
Jul 15, 2007 08:57 PM
sleeping GIANT
Oct 17, 2004 08:16 AM
s1ngle
Jul 30, 2004 04:48 AM
glagola1
Aug 22, 2003 08:51 PM
