ALL MOTOR HELP W/ SPOON STUFF
Old Nov 2, 2001 | 03:56 PM
SpoonFed's Avatar
Default ALL MOTOR HELP W/ SPOON STUFF
I WAS WONDERING IF ANYONE HAS THIS SETUP IN A TYPE R MOTOR OR HAS THE KNOWLEGDE AND WHAT THE TOTAL COMPRESSION RATIO OF THE SPOON PISTONS AND THE 1 PLY HEADGASKET IS? WHAT THE TOTAL HORSEPOWER WILL BE GAINED, I JUST HAVE STK INTERNALS BESIDE PISTONS, GASKET AND EXHAUST AND FINALLY DO YOU GUYS RECOMMEND FPR AND UPGRADED FUEL PUMP? THANKS ALOT...
Old Nov 2, 2001 | 04:25 PM
Jared's Avatar
Default Re: ALL MOTOR HELP W/ SPOON STUFF (spoonfed)
I was wondering if anyone has ever heard of not typing in all caps.
Old Nov 2, 2001 | 04:29 PM
lazyvietboi's Avatar
Default Re: ALL MOTOR HELP W/ SPOON STUFF (Jared)
Old Nov 3, 2001 | 03:17 AM
Backyard Speical's Avatar
i'm not quite sure about the compression ratio of the spoon pistons, but i believe they're are almost the same as the CTR and ITR pistons but they are rebalance by SPOON. About the spoon head gasket, its like 200 dollars i think and it increase your compression without milling the head.... i think is a weaste of money, but it does work!!!!!
[Modified by Prodigy 2.2 EK, 12:17 PM 11/3/2001]
Old Nov 3, 2001 | 03:23 AM
FSTASNTZ's Avatar
This was answered in the ITR forum.
The Spoon balanced JDM ITR pistons in a B18C5 make 11.1:1 compression. The two layer gasket bumps it to about 11.3-11.4:1. Single ply should take it to about 11.5-11.6:1.
No experience here with the 1 layer. I did run the 2 layer shortly, and have taken it off. Sealed just fine. I have heard the 1 layer is not as easy to get to seal...
Jason
Old Nov 3, 2001 | 08:26 AM
bfast's Avatar
stop screaming !! your hurting my ears !!
Old Nov 3, 2001 | 09:15 AM
bigTom's Avatar
make it ur friend... thank you and have a nice day
-ek9t
hardparked
24
Oct 5, 2009 01:00 AM
DsTeg2G
Jun 20, 2003 09:07 AM
SpoonFed
Nov 3, 2001 02:51 PM
SpoonFed
Nov 2, 2001 03:59 PM
IntegraT
Oct 6, 2001 03:54 PM
