CYLINDER HEAD GASKET SET please help
Old May 2, 2004 | 08:15 AM
Hondica's Avatar
Default CYLINDER HEAD GASKET SET please help
Hello
I have a Civic 5. gen, 1992, D15B2 engine 1.5 LSi (european) with dual point injection, Eg4, 90HP
my chassis number is: JHMEG43500s027350
Is this head gasket kit the one for me or not ?
HONDA part no:
06110-p08-010
Thanks
greetings from SLOVENIA, Europe
Old May 2, 2004 | 08:19 AM
BauleyCivic's Avatar
Risky Business
Default Re: CYLINDER HEAD GASKET SET please help (Hondica)
ANY d-series head gasket will fit your car.
Old May 2, 2004 | 08:38 AM
Hondica's Avatar
Default Re: CYLINDER HEAD GASKET SET please help (BauleyCivic)
THANKS!
so, basically you are saying that these head gasket kits including VALVE SEALS are the same?
I'm especially interested in valve seals (the one with the black and white springs, for the exhaust and intake side valves).
Are this in the above mentioned kit (see original HONDA part number) the right ones for D15B2?
Old May 2, 2004 | 08:42 AM
Risky Business
Don't know about valve seals, the head gasket itself is universal for all d-series.
Old May 2, 2004 | 08:48 AM
menkio's Avatar
y8 is the best right, 3 layer ?
Old May 2, 2004 | 08:50 AM
Risky Business
Default Re: CYLINDER HEAD GASKET SET please help (DewMota)
Thats what I use. Its a bit thinner than the non-vtec gaskets and will provide a little bump in compression. Plus its metal so you dont have to scrape it off.
Old May 2, 2004 | 08:55 AM
Hondica's Avatar
where can I find the info about valve seals, do I have the right set?
Thanks
Old May 2, 2004 | 09:09 AM
Hondica's Avatar
the set is the right one
according to this:
http://www.gaskets.com.tw/data...1.pdf
see SEQ 22
Old May 2, 2004 | 09:24 AM
menkio's Avatar
while your doing the head gasket.. why not get the entire top end gasket kit. Pretty easy to install, and it's worth it in the long run.
http://www.importperformanceparts.net/
Old May 2, 2004 | 11:53 AM
boredracer408's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Thats what I use. Its a bit thinner than the non-vtec gaskets and will provide a little bump in compression. Plus its metal so you dont have to scrape it off.</TD></TR></TABLE>
xW01FxGANGx
Jul 17, 2014 06:33 PM
dfoxengr
Oct 7, 2008 12:08 PM
runderwo
May 14, 2006 04:15 PM
db2integra
Jun 21, 2004 09:36 PM
mario82686
May 1, 2004 03:52 PM
