fuel filter for methanol
i am using an sx fuel filter with the 60micron stainless element (for meth), while prepping the car for the dyno we found **** in the tank, we checked the filter (been in the car for a year and has about 20 dyno passes on it, always flused the meth an ran the car on fuel after running it on meth) and not only found it clogged, but the **** was from it all coming apart ( the glue used to glue the element to the end caps). now i have to send my injectors to get cleaned and checked
what kind of filters you guys using, or do you just change the element often.
the filter you have to use is from fluid control call and talk to rick those fuel filters were fixed a year ago the new ones are welded together no more glue for the end caps you will not have a problem.
