fuel filter for methanol
Old May 2, 2004 | 07:40 AM
boostedr's Avatar
Default fuel filter for methanol
i am using an sx fuel filter with the 60micron stainless element (for meth), while prepping the car for the dyno we found **** in the tank, we checked the filter (been in the car for a year and has about 20 dyno passes on it, always flused the meth an ran the car on fuel after running it on meth) and not only found it clogged, but the **** was from it all coming apart ( the glue used to glue the element to the end caps). now i have to send my injectors to get cleaned and checked what kind of filters you guys using, or do you just change the element often.
Old May 2, 2004 | 08:08 AM
turbo96wr's Avatar
Default Re: fuel filter for methanol (boostedr)
the filter you have to use is from fluid control call and talk to rick those fuel filters were fixed a year ago the new ones are welded together no more glue for the end caps you will not have a problem.
Old May 2, 2004 | 10:05 AM
bambooluv's Avatar
Default Re: fuel filter for methanol (turbo96wr)
what Willie said, or look into the weldon units. goodluck-pdang
Old May 2, 2004 | 03:46 PM
boostedr's Avatar
Default Re: fuel filter for methanol (bambooluv)
how about the aeromotive 100micron element
adam00
Mar 11, 2010 09:31 AM
turboxsi
Jan 16, 2004 07:50 PM
Lei Siew Long
Mar 3, 2003 04:52 PM
