Smell of oil.... where is it coming from?
Old May 2, 2004 | 01:34 AM
Moonbus's Avatar
Default Smell of oil.... where is it coming from?
Hello guys,
Need some advise. Recently, after I redlined the car, I can smell some burning smell... like it u drive it hard without enough engine oil... I have checked my oil level and it was ok... not sure if you have any similar experience? Or do u know what is the cause?
Thanks!!
Old May 2, 2004 | 06:49 AM
Bbasso's Avatar
Default Re: Smell of oil.... where is it coming from? (Moonbus)
Smelling oil after beating on your car is somewhat normal, but "drive it hard without enough engine oil" is not normal or too bright.
Old May 2, 2004 | 01:10 PM
vtec.dc2's Avatar
whats your setup.. is your car stock, running boost, n/a, oil cooler or whatever..
Old May 2, 2004 | 03:47 PM
Champ R's Avatar
Default Re: Smell of oil.... where is it coming from? (vtec.dc2)
I get the oil burning smell occasionally when i redline a few gears, almost always when entering the freeway on a clear on-ramp
Old May 2, 2004 | 04:31 PM
.RJ's Avatar
.RJ
valve cover gasket, cam seals (either end), oil pan gasket, oil separator box.
Old May 2, 2004 | 06:06 PM
Stryker's Avatar
i have the same problem
Old May 2, 2004 | 08:06 PM
dk127's Avatar
are you sure its oil? not clutch? sometimes i can smell my clutch..
Old May 2, 2004 | 08:12 PM
Stryker's Avatar
Default Re: (dk127)
yeah im sure
Old May 3, 2004 | 06:49 AM
Moonbus's Avatar
Default Re: (Stryker)
Hi guys, did not know I am not the only one that has the problem.
So we can consider this normal?
How do u know if it is the clutch not the oil?
I have Mugen intake & exhaust, and am using fully synthetic 5W30 oil.
Thanks guys!!
Old May 3, 2004 | 06:51 AM
typer_801's Avatar
Default Re: (Moonbus)
It's normal.
Old May 3, 2004 | 09:31 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moonbus &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys, did not know I am not the only one that has the problem.
So we can consider this normal? </TD></TR></TABLE>
Did you guys even see my post?
Old May 3, 2004 | 11:22 AM
MK Ultra's Avatar
Default Re: Smell of oil.... where is it coming from? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">valve cover gasket, cam seals (either end), oil pan gasket, oil separator box.</TD></TR></TABLE>
Also worth checking is the oil filter. If it leaks it drips directly onto the exhaust manifold.
mohater
22
Sep 7, 2012 05:01 AM
MumBleZ_94gsR
May 30, 2009 03:26 PM
IntegraType-R
25
Nov 5, 2007 04:58 PM
yuen
Nov 12, 2006 06:43 AM
mixxed
Jun 27, 2003 07:52 AM
