Full Integra DA Disc brake conversion! Help --> Upper Control arms (UCA) are hitting fender
Old May 1, 2004 | 11:27 PM
Toptul_Honda's Avatar
New User
Default Full Integra DA Disc brake conversion! Help --> Upper Control arms (UCA) are hitting fender
I have a problem with my set up. I just spent the last few days putting on the full integra disc brake conversion. I have a problem with the front UCAs hitting the fender!
My setup:
- Koni Yellows with HR race springs (2" Drop)
- Ebay camber kit with CRX UPPER CONTROL ARMS
- integra front knuckles
WHAT is your setups?! SO i can determine whats wrong?
Maybe i have to adjust the camber kit to work....
HELP!
Modified by G2-Rex at 12:44 AM 5/2/2004
Old May 1, 2004 | 11:38 PM
EL Vap133's Avatar
Default Re: Full Integra DA Disc brake conversion! Help --> Upper Control arms (UCA) are hitting fender (
Weird, I don't have that problem.
Old May 1, 2004 | 11:43 PM
New User
what is your setup?
Old May 1, 2004 | 11:52 PM
EL Vap133's Avatar
91 Teg knuckles, Progress spring for EF w/B-series, stock struts.
Old May 1, 2004 | 11:54 PM
New User
how much of a drop? wnat UCA did you use? and camber kit?
Old May 1, 2004 | 11:57 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2-Rex &raquo;</TD></TR><TR><TD CLASS="quote">how much of a drop? wnat UCA did you use? and camber kit?</TD></TR></TABLE>
No camber kit, I used the stock UCAs, I don't know exactly how much of a drop it is but it's not slammed.
P.S. It said your PMs are disabled.
Old May 2, 2004 | 12:38 AM
New User
i see, so with the stock UCas you didnt have any camber problems?
Old May 2, 2004 | 06:40 AM
splinter51's Avatar
dont feel to bad with camber adjusters for arms on stock front. my arms come within a 1/8 inch. i trimmed the lip inside about 3/8 inch and it clears better.
Old May 2, 2004 | 07:54 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2-Rex &raquo;</TD></TR><TR><TD CLASS="quote">i see, so with the stock UCas you didnt have any camber problems?</TD></TR></TABLE>
Nope, car drives like a champ!
Old May 2, 2004 | 08:07 AM
kylefakesi-r's Avatar
teh integra ones hit the inner fender when i did mine...to correct it i used the civic ones and an adjustable ball joint.
Old May 2, 2004 | 12:24 PM
New User
i fixed it with the camber kit. But the arms are slanted upwards quite agressively....
it probably has a few inches before it hits the top!
anyways i just need an alignment and fix the steering and i hope itll drive like a champ!
I still need to change the prop valve since the bolts were a bit rounded and tough to break loose!
anothersickhatch
Suspension & Brakes
10
Feb 5, 2007 10:48 AM
CRX_Control
Nov 9, 2005 02:48 PM
91sihatchback
10
Jul 28, 2003 09:45 PM
