weird intake humming noise
Old May 1, 2004 | 10:14 PM
omeara7's Avatar
Default weird intake humming noise
My intake is making a weird humming noise sometimes at idle. Any idea what that could be? It only happens at idle when the RMP is between 500-700. The humming comes from the filter I'm pretty sure, so I doubt it's anything to worry about.
Old May 1, 2004 | 10:19 PM
accordselux's Avatar
Me Gusta History
Default Re: weird intake humming noise (omeara7)
stock or aftermarket?
Old May 1, 2004 | 10:30 PM
FatJoe's Avatar
Default Re: weird intake humming noise (accordselux)
its not a high pitched humming noise is it?
Old May 2, 2004 | 07:59 AM
omeara7's Avatar
Default Re: weird intake humming noise (FatJoe)
The filter is aftermarket, and the noise is not hight pitched, it's definately a lower sounding pitch.
Old May 2, 2004 | 08:50 AM
jwogen1's Avatar
its just the intake drawing air---supposed to sound different than a stock air box
Old May 2, 2004 | 09:41 AM
pyrojeff's Avatar
Default Re: weird intake humming noise (jwogen1)
Yeah, this is just something that happens naturally with the new intake. Just be glad its not like my friend's integra, friggin thing squeals like crazy once it hits 2500 rpm.
Old May 2, 2004 | 11:17 AM
omeara7's Avatar
yea, I was pretty sure that it was nothing and just the intake sucking in air. Thanks a lot
Old May 2, 2004 | 12:02 PM
fw190bvi's Avatar
Default Re: (omeara7)
if its really quiet and u flick the gas @ idle, itll sound like a reverse blow off valve, FatF style....bwahahahhaa.....works best in a garage
Old May 2, 2004 | 05:34 PM
omeara7's Avatar
Default Re: (fw190bvi)
haha yea i do that once and a while. When it first sucks in air it sounds cool.
Old May 2, 2004 | 07:40 PM
RUBZERK's Avatar
I got that same sound also with my factory intake, how do i get rid of it ?
Old May 2, 2004 | 07:44 PM
spankey167's Avatar
Default Re: (RUBZERK)
Its the stock air box resonator that is inside your bumper. Its got to be taken out to get ride of the humming noise.
Old May 3, 2004 | 11:13 AM
Mike813's Avatar
Default Re: (spankey167)
i like that noise actually, doesnt bother me one bit when the hoods closed or if im behind the wheel.
Old May 3, 2004 | 12:11 PM
BoostedH23Accord's Avatar
An adjustment to the idle screw on the throttle body (if you turn it down) the sound will diminish. Thats questionable depending on where your idle is set, but you can cause your car to burn more gas at idle if you turn up. If worse comes to worse put the factory parts back on.
Good luck.
Old May 3, 2004 | 12:14 PM
omeara7's Avatar
Default Re: (Mike813)
I dont know why you're getting that hum with the stock air-box and filter, but I guess it has something to do with the RPM because it's pulling in just the right amount of air to make that humming noise. I dont think there's anything we can do really. --Oh well-- It isn't too annoying, but it wasn't there until recently.
Does anyone know why my idle jumps from 700-1500 at times (usually when it's cold and raining)? I think it might have something to do with the resistor I have in there b/c it's messing up the intake temp reading.
Old May 3, 2004 | 02:08 PM
LeMoN_GrAsS's Avatar
do you have an cold air intake???becuase i have one and my intake hums too...and i was told that cold air intake is going to do that to the intake...so no big deal...let it hum...to show that you have an intake...lol...
Old May 3, 2004 | 02:16 PM
omeara7's Avatar
Default Re: weird intake humming noise (LeMoN_GrAsS)
yea i have an aftermarket intake but I find that it started humming as the weather here in PA got warmer. The temp isn't effecting it I dont think. I dont care, I was just curious if there was a reason but I guess not. Thanks
sohctodohc
Aug 19, 2009 05:02 AM
vancouverdc4
Jun 20, 2007 08:11 PM
casmello
Jan 21, 2005 01:11 PM
BeerBaron105
Feb 1, 2004 08:33 AM
97teg415
Sep 3, 2002 08:46 PM
