ROTORS (looking for 4x100 with diameter of itr/legends)
Old May 1, 2004 | 09:08 PM
egjdm03's Avatar
Default deleted
Modified by egjdm03 at 1:32 AM 7/27/2004
Old May 1, 2004 | 09:24 PM
Sliced Beard's Avatar
Default Re: ROTORS (egjdm03)
just get some prelude rotors and redrill them for 4x100 and you will be set
do not worry about the holes being exactly center because the center of the rotor is hubcentric
just use your old rotor as a template and drill away
Old May 1, 2004 | 09:43 PM
egjdm03's Avatar
Default Re: ROTORS (dirtyd463)
ive thought bout redrillling rotors to my 4x100 lug pattern, but how dependable is tat...also cost??? but at the moment i would like to know if anyone has upgraded their 4 lugs to diameter size of legends/itr, if so where...thanks for the quik reply...
Old May 1, 2004 | 09:53 PM
it is a very common conversion
i have now seen this same thing done on three cars now and one two are used as race cars, therefore i would think it works well.
the cost should be no more than maybe 130
th8ink about it
36 bux a piece for remanufactured calipers at auto zone
then you can get some 98 non SH prelude front rotors and redrill them , the rotors costing roughly 20 smackaroos a piece
VOILA big brake upgrade at a budjet price
Old May 1, 2004 | 10:02 PM
egjdm03's Avatar
i might end up doing it this way...
Old May 1, 2004 | 10:08 PM
jetpilot's Avatar
what reman calipers should I buy at autozone?
Old May 2, 2004 | 08:12 AM
Default Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote"> get some 98 non SH prelude </TD></TR></TABLE>
or you can get some Accord wagon calipers or just find a set of ITR calipers
Old May 2, 2004 | 08:43 AM
Dan GSR's Avatar
Default Re: (dirtyd463)
vw corrado G60
Old May 2, 2004 | 09:41 AM
thenick's Avatar
Default Re: (Dan GSR)
i was just gonna say corrado
Old May 2, 2004 | 10:55 AM
feriocious's Avatar
Default Re: (ixiblindixi)
What year corrado would we be looking for? And are they already drilled for 4x100?
Old May 2, 2004 | 12:45 PM
egjdm03's Avatar
Default Re: (Scissor)
if i redrilled a 4x100 pattern into the 5 lug disc(legends)...would i need some bracket to hold up the legend calipers....
calipers bolt up evenly (with 10.2 rotors) but i have a feelings i would need a bracket for correct fitment if i were to use bigger rotors on the gsr knuckle of minds with legend calipers...anyone wit experience on this would appreciate the help...
Old May 2, 2004 | 01:03 PM
xerox445's Avatar
Default Re: (egjdm03)
redrills suck because they are always off ballance...
Old May 2, 2004 | 01:12 PM
slammed_93_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egjdm03 &raquo;</TD></TR><TR><TD CLASS="quote">if i redrilled a 4x100 pattern into the 5 lug disc(legends)...would i need some bracket to hold up the legend calipers....
some one gave you a car that has the 4x100 bolt pattern and everything else the same with the ITR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">vw corrado G60</TD></TR></TABLE>
now i don't like the idea of re-drilling rotors and brembo doesn't suggest it either. but Emerika (ht username) runs them and has never said anything bad about them
now as far as needing a bracket for the fitmint, i went from 10.2 to 11.1 on a 97 ITR with this same conversion and the caliper bolted up just fine, you will have to watch the clearance from the caliper to the inside of the spoke on the wheel
Old May 2, 2004 | 01:17 PM
xerox445's Avatar
Default Re: (slammed_93_hatch)
i thought emerika said he gets crazy vibration at highway speeds? mabey it was someone else...
obviously it was someone else
Old May 2, 2004 | 01:18 PM
Evs-One's Avatar
Solbros Owns Me
yup, I've never had a problem with redrilling rotors.
AJ Racing also redrills ITR rotors to use Spoon calipers on 4x100 cars and they haven't had problems either.
And I believe Chad does also
Old May 2, 2004 | 01:22 PM
jcarothers's Avatar
so would these be the same diameter as the prelude, but with the right bolt pattern? also, would these just pop on or is there some work invovled to get them to work? thanks.
Old May 2, 2004 | 01:27 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">i thought emerika said he gets crazy vibration at highway speeds? mabey it was someone else...
obviously it was someone else</TD></TR></TABLE>
I got some vibration at highway speeds when using ITR rotors. People who redrill ITR rotors need to run hubcentric spacer because the ITR rotor hub is larger than the Civic/4x100 hub. I switched to Lude VTEC rotors, which are same hub size, and now there is no vibrations
Old May 2, 2004 | 07:31 PM
Default Re: (Emerika)
yes chad does have them redrilled
on BOTH race cars
i am a local to the shop he works at and it was his cars i was referencing to
and lude rotors are the way to go, like just stated they are hubcentric with an integra/civic knuckle/hub
Old May 2, 2004 | 07:50 PM
Civic96LX's Avatar
OK, if ya wanna just buy some, check here, they should have it, they do a lotta conversions/
http://www.passwordjdm.com
Old Sep 11, 2004 | 02:37 PM
STN_Pat's Avatar
Default Re: (jcarothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcarothers &raquo;</TD></TR><TR><TD CLASS="quote">so would these be the same diameter as the prelude, but with the right bolt pattern? also, would these just pop on or is there some work invovled to get them to work? thanks.</TD></TR></TABLE>
ttt i wanna know that
Old Sep 12, 2004 | 09:02 PM
Default Re: (STN_Pat)
supposedly every thing spec wise is right on.
now people are willing to throw around the name and stuff but i have never goten any more info then that out of them.
Old Sep 12, 2004 | 09:17 PM
xerox445's Avatar
im doing the whole conversion, any questions, feel free to ask me, mine is done, minus the rotor drilling....NOTE: Have a machine shop do it, my first one came out really bad, even with using a 4 x 100 rotor on top clamped to it...it dont work well, spend the money and have someone that knows what they are doing redrill them. I just waisted like 30 bucks on a brand new 96 vtec blank
20vsleeper
Jul 25, 2007 09:14 PM
ATS*Mark
Aug 7, 2005 05:53 AM
babemonster_bo
Dec 28, 2004 11:20 AM
Project X
Jul 23, 2003 12:40 PM
itr1236
Sep 18, 2002 02:23 PM
