question for oil pan baffling
I baffled my own oil pan. has any one else done this? if so did you warp your pan?
I have a oil pan leak and it kinda looks like I may have done this.
new oil pan or no what you guys think
you probally blew a hole thru it when you welded it, too much heat. Turn down the amps and wire speed (if it's a wig welder) and you'll be fine if go slow. If you didnt weld it then take it back to the place that did and ask them to fix it
no holes just thought the pan may have warped a little. enough to leak a drip every minute or so it may just be the oil pan gasket too
