Im hoping to
Old May 1, 2004 | 07:44 PM
8200RPM's Avatar
local hippie
Default car sputter...
Im hoping to get some input from some of you guys on here, my car is driving pretty wierd lately and I thought I had fixed the problem...
96 d16y8 w/ ~180k miles.
car basically bogs anywhere between 1000-3500 RPMs. This isnt all the time, just every now and then but its been happening more frequently lately. The car was barely driveable a few months ago, sputtering really bad, so I changed the plugs, wires and distributor cap bc upon inspection of it- I noticed where cyl #2 plugs in it was corroded. This work fixed the problem.
(giving as much info that might be helpful to diagnose the problem)
When I drive the car, sometimes, lets say for example around 2500 rpms it feels & sounds like its stuck- you push the accelerator but it hesitates to keep driving smoothly. Other times its less noticeable and as you're driving it feels like the car "skipped a heart beat".
I know this shouldn't be too hard to figure out- just hoping someone could point me in the right direction.
Im thinking it must be ignition related, could it be fuel related?
CLIFF NOTES: car has a periodic sputter between 1000-3500 rpms.
TIA
Modified by 8200RPM at 10:55 AM 5/2/2004
Old May 1, 2004 | 07:51 PM
crxY-49's Avatar
Default Re: Im hoping to (8200RPM)
take your dizzy cap off and check all your ignition wires. Does your tach jump when this happens? if so its probably a loose wire in there. I would inspect the internals of your distributor. rotor/cap/wires
Old May 2, 2004 | 10:09 AM
8200RPM's Avatar
local hippie
Default Re: Im hoping to (crxY-49)
thanks, ill do that....
no the tach doesnt jump- it actually looks like it stays stuck
Jorsher
Jul 21, 2006 09:55 AM
CleanLikeJdm
May 23, 2005 08:03 AM
8200RPM
May 11, 2004 08:01 PM
Jon5240
Oct 25, 2003 08:35 PM
XEF-9X
Oct 5, 2002 07:57 PM
