ignition switch?
Old May 1, 2004 | 07:40 PM
AmericanHonda's Avatar
Default ignition switch?
puttin in new tach, how do i tap into the fuse pannel for the ignition? or is there a different way/better way?
Old May 1, 2004 | 08:09 PM
john666's Avatar
Default Re: ignition switch? (AmericanHonda)
ummmm depending on car.. if its a civic.. were the fuses are. there are open slots that you can plug the ign. wire into. all you need is a female connector and maybe a light tester to see which one it is.. ive seen people also plug it into there stereo ign. wire. but i imagine its up to u.
Old May 1, 2004 | 08:12 PM
Default Re: ignition switch? (john666)
plugging into a random one wuold work? i always thought you had to splice off the ignition wire. thanks. and yes it is a civic.
Old May 1, 2004 | 08:24 PM
john666's Avatar
Cant find my digital cam.. i believe its the third one from the right... the slot looks like a box with a - in the middle..each slot is for different things.. 1 slot is for when car is on, when lights are on and etc. if im incorrect about the slot just play with it a bit and you will find it.. there are only 5 so shouldnt take too long.
Old May 1, 2004 | 08:38 PM
sweet thanks
speedjunkie_g35
17
Oct 21, 2012 09:15 AM
EH3 JR
Apr 27, 2009 04:43 PM
Turbo_y8
Aug 25, 2004 12:22 AM
JSPECHB
Feb 21, 2004 08:07 AM
JSPECHB
Feb 17, 2004 02:30 PM
