where is the relay for the passenger door's Power Window motor?
My 1day old '01 S get's this problem...after I clean the interior, the passenger window will not work. I checked the fuses...fine. I cannot hear the relay click when I press the switch on either door, so I'm guessing that's the problem (the relay would still click if the motor were bad). the switch iself is connected right.
i took the door apart and pulled the motor coils so that i could raise the window.
anyone know where the relay is and if i can get one at autozone. or, anything wrong with my diagnosis?
have you checked this fuse? it's #51 in this picture, it's reated to the fuses under the dashboard that control the driver and passenger window motors.
http://www.imagestation.com/pi...2.jpg
Have you checked the rocker switch just forward of the window switches on the driver's door? That rocker switch is a lock-out for the passenger window which applies to both switches (passenger and driver). I hope that it is that easy for you (the rocker switch was probably bumped when you were cleaning).
kptrk06
Honda Civic (2001 - 2005)
Jun 29, 2014 09:26 PM
einzelherz
Dec 16, 2011 02:58 PM
