Problems with our new Jackson racing supercharger
Old May 1, 2004 | 06:22 PM
edelbrock99CivicEx's Avatar
Default Problems with our new Jackson racing supercharger
First of all, i have a 1999 honda civic EX 1.6L D16Y8. Alright, i'm not that mechanically inclined, without my friend i wouldn't of been able to install this supercharger. I have some problems with my car. First of all, it's fast as hell, the supercharger works. But there are some problems. The check engine light is on, does anyone know how to reset that? Second of all, my RPM will fluctuate. It wants to idle at 2000rpm sometimes, and sometimes it wants to idle at 0 and die. Now as much as we adjust the throttle cable, we can't seem to get it right. There is some hissing around the throttle body as if the gasket may not be working, but i'm not sure. Does anyone have any suggestions to this problem?
Old May 1, 2004 | 06:45 PM
RACESMART's Avatar
Default Re: Problems with our new Jackson racing supercharger (edelbrock99CivicEx)
sounds like a vacum leak
Old May 1, 2004 | 06:53 PM
Default Re: Problems with our new Jackson racing supercharger (RACESMART)
vacuum hoses need hose clamps or what?
Old May 1, 2004 | 07:12 PM
Cruiser G's Avatar
yea you could be missing a vacuum hose somwhere or it has a hole in it. Also your throttle body gasket and/or possibly intake manifold gasket might not be sealing well. Try spraying some carb cleaner around the gaskets with the engine running and watch for bubbles, that would mean a leak. good luck
Old May 1, 2004 | 08:31 PM
Default Re: Problems with our new Jackson racing supercharger (Cruiser G)
carb cleaner? just buy that at autozone or what?
Old May 2, 2004 | 08:39 AM
Cruiser G's Avatar
yea, its an aresol spray
Old May 3, 2004 | 12:46 PM
alright, well, i found the leak, thanks to the info, it was the throttle body gasket, the last place i looked because i spent $29 at my local honda dealer, and purchased a brand new one, and it didn't work. So, i used liquid gasket to seal it, not professional, but it sure did work. Well, anyways, the check engine light is on, should i pull the fuse to reset it? Also, the throttle cable is off, no matter what i do, the rpm will run about 1200rpm unless i put my foot under the gas pedal and push up, then it will run right at a about 500rpm. New throttle cable, or is there any suggestions on how i can rig this?
by the way my rpm runs high in idle sometimes, once up to speed, it is ok
Old May 4, 2004 | 01:15 AM
anyone?
Old May 4, 2004 | 11:50 AM
warrick's Avatar
if you can move the pedal and drop the idle, it's most likely a sticky throttle cable or something of that sort. double check that nothing is interfering with the cable, and that it is properly tensioned/adjusted.
thewrai6th
Sep 13, 2011 05:19 PM
the_dxB16
Mar 13, 2008 10:47 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
CRX_Control
Nov 7, 2004 07:47 PM
metal-x
Nov 21, 2002 05:35 AM
