'95 Civic EX, Do I have ABS???
Old May 1, 2004 | 04:32 PM
klovewell's Avatar
Default '95 Civic EX, Do I have ABS???
I just purchased a '95 Civic EX. How do I tell if this model has ABS or not? I need to replace an axel and need to know which part to buy...
Thanks,
K
Old May 1, 2004 | 04:35 PM
B18C4-T's Avatar
Default Re: '95 Civic EX, Do I have ABS??? (klovewell)
The 2 easiest ways are:
A: When you turn the key to the on position is there an ABS light on? If there is then you have ABS.
B: Look and see if you have rear disc brakes, if you do and the car is STOCK then you have ABS.
Old May 1, 2004 | 04:59 PM
csprague's Avatar
The easiest way to tell if you have ABS is to attempt to lock up the wheels and see if it kicks in or not.
Barring that you can always look in the rear as mentioned before and check for disks. All EX sedans of that year should have disks/ABS standard, if you happen to have a four-door.
Old May 1, 2004 | 05:29 PM
BLUTO's Avatar
Yeah, when you turn the ignition on there should be an ABS light that turns on. If I am not mistaken, EX's do not have ABS... I could be wrong though.
Old May 1, 2004 | 05:49 PM
EX R8ED's Avatar
Default Re: '95 Civic EX, Do I have ABS??? (B18C4-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C4-T &raquo;</TD></TR><TR><TD CLASS="quote">The 2 easiest ways are:
B: Look and see if you have rear disc brakes, if you do and the car is STOCK then you have ABS.</TD></TR></TABLE>
Not true, some 5th Gen EX model Civics came without ABS but with rear discs...like mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by csprague &raquo;</TD></TR><TR><TD CLASS="quote">The easiest way to tell if you have ABS is to attempt to lock up the wheels and see if it kicks in or not.
Thats the dumbest thing I've heard in a while
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUTO &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, when you turn the ignition on there should be an ABS light that turns on. If I am not mistaken, EX's do not have ABS... I could be wrong though.</TD></TR></TABLE>
Some EX models did have ABS.
An easy way to check is to open your trunk. On the passenger side, under the carpet you will find the ABS module if you have ABS.
Another easy way is to open your hood and look for the ABS fuse box.
Old May 1, 2004 | 08:34 PM
95b18civ's Avatar
look under the hood for the abs fuses or for rear disc brakes, or if you have the computer in the trunk on the left hand side.
Old May 1, 2004 | 08:35 PM
95b18civ's Avatar
Default Re: '95 Civic EX, Do I have ABS??? (BLUTO)
some ex's do have abs.
Old May 2, 2004 | 10:31 AM
BLUTO's Avatar
Default Re: '95 Civic EX, Do I have ABS??? (EX R8ED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX R8ED &raquo;</TD></TR><TR><TD CLASS="quote">
My bad. on me.
Old May 2, 2004 | 11:19 AM
sohcvtec1995's Avatar
look for a huge square thing with brake lines going to it under the hood, right by yourstock air box.
Old May 2, 2004 | 11:23 AM
xerox445's Avatar
Default Re: '95 Civic EX, Do I have ABS??? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">look for a huge square thing with brake lines going to it under the hood, right by yourstock air box.</TD></TR></TABLE>
Exactly, its huge, you cant miss it, and nothing else looks similar
95jdmcivic
May 27, 2008 11:41 AM
EJmugen
Oct 6, 2007 05:35 PM
george34
Jun 27, 2005 11:01 AM
KiDSoL
Jan 19, 2004 09:21 PM
Turbohatch
25
Jan 3, 2003 02:02 PM
