help my car wont go into first!!!!
Old May 1, 2004 | 02:18 PM
dcsports's Avatar
Default help my car wont go into first!!!!
well as title says my car wont go into 1st gear it does at time if u play with it will go into 1st gear i know my clutch is gone but it was working before... i have a new exedy oem replacement clutch on the way.. i dunno wat happend i jus changed my tranny fluid couple mins ago still does it do u think its because my clutch is gone or something else is going on?
Old May 1, 2004 | 02:20 PM
TorganFM.'s Avatar
Default Re: help my car wont go into first!!!! (dcsports)
Is there pressure behind your clutch pedal? Push the car a little or have a friend do it while you sit in the car with the clutch in and pressing on 1st gently. Don't press too hard or the crappy shift forks will snap.
Old May 1, 2004 | 02:25 PM
dcsports's Avatar
Default Re: help my car wont go into first!!!! (DanW)
naw i feel no pressure to tell u the truth my pressure plate is gone lol it makes this weird soft sound when i push the clutch pedal in .. and its soft as hell i feel no real push bak from the clutch pedal
Old May 1, 2004 | 02:30 PM
dcsports's Avatar
bump
Old May 1, 2004 | 03:06 PM
GReddy SI's Avatar
bump . i dont know whats wrong , 2 days ago it was fine
now it dont want to go into first ! errrrrrrrr
we just changed the tranny fuild and still same problem
Old May 1, 2004 | 03:45 PM
dcsports's Avatar
bump anyone alive?
Old May 1, 2004 | 04:16 PM
TorganFM.'s Avatar
Check your master cylinder and clutch fluid levels. Open the hood, facing the windshield from the bumper the clutch reservoir is the upper right-most bottle thingy.
Old May 1, 2004 | 05:12 PM
GReddy SI's Avatar
they are full
where is the shift fork in the tranny?
Old May 1, 2004 | 05:44 PM
dcsports's Avatar
Default Re: help my car wont go into first!!!! (GReddy SI)
damm is h-t dead today?
Old May 1, 2004 | 06:30 PM
91lsvtecrx's Avatar
it's not your pressure plate, it's you clutch master cylinder or the slave cylinder need to be relaced.
Old May 1, 2004 | 06:36 PM
LSVtecEK1's Avatar
Default Re: help my car wont go into first!!!! (91lsvtecrx)
try bleeding the clutch, the slave cylinder probably isnt holding any pressure.
Old May 1, 2004 | 10:48 PM
dcsports's Avatar
Default Re: help my car wont go into first!!!! (AllMtrADVAN)
thanks for replies will try tommorow
Old May 1, 2004 | 11:06 PM
xerox445's Avatar
bleed the system, your PP could be shot tho, and you cant disengage the clutch, happened 2 me. Had 2 start it up in 1st gear and powershift everywhere and rev match for a while till i got funds to fix it. Made me a better driver.
redline7
Feb 23, 2008 08:53 PM
mikeycivic
26
May 16, 2007 10:44 AM
hellrsnCL
Aug 10, 2005 08:29 AM
vtec69
20
May 4, 2005 05:48 PM
jonoknut
Dec 26, 2002 11:56 AM
