Engine Whine at low rpm
Old May 1, 2004 | 01:14 PM
troubledsol03's Avatar
Default Engine Whine at low rpm
93 Delsol Si with LS/VTec turbo it is making a funny whine at low rpm no power steering or ac and i took the alt belt off thinking it might be that any other ideas it does seem to be coming from the timing belt side
Timing belt?
Water pump?
Oil pump?
Tensioner?
Cams?
Any Help would be great
Thanks
Already searched
Old May 1, 2004 | 02:02 PM
Default Re: Engine Whine at low rpm (troubledsol03)
Hello!
Old May 1, 2004 | 02:08 PM
tilt's Avatar
id def look at the tbelt, tensioner, and water pump.
Old May 1, 2004 | 02:17 PM
after_effx's Avatar
Default Re: Engine Whine at low rpm (tilt)
check pully bearings. they sometimes go bad. also the harmonic balancer can go bad too. but definatly check if it is coming from the timing belt. could be something loose or worn out.
taadas
Apr 11, 2016 06:20 AM
5.56
Jun 17, 2009 05:19 PM
ak
Feb 9, 2009 01:52 PM
05member y0
Aug 29, 2005 03:18 AM
Cspeclude
Feb 4, 2003 03:05 PM
