SPEEDOMETER CABLE!
Old May 1, 2004 | 12:22 PM
youngwon22's Avatar
Default SPEEDOMETER CABLE!
This is 2nd time i'm replacing my cable, and last one had snapped after a week and i wanted to know how to pick one that will last?
TIA
Old May 1, 2004 | 02:29 PM
VtecDeMoN's Avatar
Default Re: SPEEDOMETER CABLE! (youngwon22)
Hmm... OEM is fine. Are you buying used ones or new ones? If buying used they might have a kink in them causing them to weaken and break. Also make if you have a swap you are using the correct one for it. You didn't specify your setup so I couldn't give any specific advice for that.
Brian
Old May 1, 2004 | 03:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngwon22 &raquo;</TD></TR><TR><TD CLASS="quote">This is 2nd time i'm replacing my cable, and last one had snapped after a week and i wanted to know how to pick one that will last?
TIA</TD></TR></TABLE>
Keep the bends as wide an smooth as possible. Grease up the core real good.
Old May 2, 2004 | 10:55 AM
youngwon22's Avatar
Default Re: SPEEDOMETER CABLE! (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN &raquo;</TD></TR><TR><TD CLASS="quote">Hmm... OEM is fine. Are you buying used ones or new ones? If buying used they might have a kink in them causing them to weaken and break. Also make if you have a swap you are using the correct one for it. You didn't specify your setup so I couldn't give any specific advice for that.
Brian</TD></TR></TABLE>
look at my sig
alupso
Dec 16, 2006 04:42 PM
Mr. Giggles
Aug 11, 2006 05:21 AM
john d
Jan 15, 2005 09:35 PM
nonsense
15
Apr 9, 2004 03:55 PM
speedracer33
28
Jul 23, 2003 06:28 PM
