did search but need help, going from NA to turbo
I have a b18 block, fresh rebuild, CTR pistons, ls rods (shotpeened), decked
ls head, ported polished, shaved, daul valve springs and upgraded retainers, I have SS valves, gatting cams soon, now my questions is, my origianl setup was for NA but I want to go turbo, I also have a skunk 2 intake mani, and a 62 mm throttle body
What cams should I get and what size turbo and boost can I run on my current system I kinow boost and high comp dont go well together, so should I get new pistons, basically for you Turbo buffs, I want a reliable 300 HP car, I figure anything more then taht is no longer very reliable. the block and head are fresh from the shop, just done and hottanked, so if I change anything it has to be now.
Thanks for the help
Thanks for the help
thanks for the replies guys, so I can go with CTR pistons? and what should I do for ECU, chip it or get Hondata, anso, what cams would be good to run with boost, and lastley, what size turbo should I go? tahnsk again.
