92 h22 civic si needs brakes!
with the new motor in, i need better stopping power, i was looking into the oversized aem carbon black rotors,u use oem parts and it supposedly bolts up. i noticed though that their available only for civics with abs, i dont think mine has abs. will they still work? how bout the rear discs? i basically want new rotors( cross or slotted) for the front and rear and ill order the pads from the honda. any suggestions?
Braded lines
pads
better rotors stock sized
brake flush put dot 5 back in, pretty purple ownz u!
try that stuff before you spend a whole lot of money on stuff you dno't need.
pads
Don't waste your money on the AEM kit
