good settings for 12.3 comp CTR cams?
I have a GSR block with Pr3 pistons ITR head ported shaved .33thou , msd, fpr, CTR cams with ajd gears running around 12.3 compression using 94 octane only. What cam gear setting's should I start with? any tips??? TIA Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades »</TD></TR><TR><TD CLASS="quote">if i were you i'd have that done on a dyno jet</TD></TR></TABLE>
I will be going to the dyno very soon just wanted to get a good base line. Rob
