bought used springs, which one is front & rear? *pic*
Old Apr 30, 2004 | 07:58 PM
Red!ine's Avatar
Default bought used springs, which one is front & rear? *pic*
just want to make sure before i install them, thx in advance
Old Apr 30, 2004 | 08:00 PM
eric8876's Avatar
Default Re: bought used springs, which one is front & rear? *pic* (kAoTiK)
right ones are front
Old Apr 30, 2004 | 08:02 PM
Red!ine's Avatar
Default Re: bought used springs, which one is front & rear? *pic* (eric8876)
alrighty
Old Apr 30, 2004 | 08:18 PM
mpintegra96's Avatar
stand them all up next to each other than take another pic then i could tell, cant really tell lookin at that
Old Apr 30, 2004 | 08:27 PM
stumpyf4's Avatar
Ones with the thicker diameter wire are the fronts, the ones in the right in the pic.
Also with Prokits, the fronts are straight spring rate and the rears are progressive spring rate.... Progressive will have varying spacing between the coils while straight has even spacing.
Length of spring has nothing to do with it... both are around the same length.
Old May 2, 2004 | 11:07 AM
juniordc2's Avatar
usually the fronts are flat at the ends, where as the rear spring coils just end.
Old May 2, 2004 | 02:04 PM
IntEGNYC's Avatar
Default Re: bought used springs, which one is front & rear? *pic* (dc2gsr94)
the tighter coils go in the front.
Old May 2, 2004 | 02:21 PM
mingbling's Avatar
they should say.. front and rear on the springs..
Old May 2, 2004 | 03:12 PM
eurojdm's Avatar
try to compare them to you oem ones. of course those eibachs are goin to be smaller, but check the rotation of the coil to the base of where it lies on the shock....
Old May 2, 2004 | 10:28 PM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2gsr94 &raquo;</TD></TR><TR><TD CLASS="quote">usually the fronts are flat at the ends, where as the rear spring coils just end. </TD></TR></TABLE>
Nope, both front and rear come with unground ends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">the tighter coils go in the front.</TD></TR></TABLE>
I agree
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling &raquo;</TD></TR><TR><TD CLASS="quote">they should say.. front and rear on the springs.. </TD></TR></TABLE>
Nope... they only have the part number and Eibach logo. Part number can be used to distiguish but I can't remember what were the part numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eurojdm &raquo;</TD></TR><TR><TD CLASS="quote">try to compare them to you oem ones. of course those eibachs are goin to be smaller, but check the rotation of the coil to the base of where it lies on the shock....</TD></TR></TABLE>
OEM are a hell of alot longer than the prokits. You can actually put the front springs on the rear of the car and vice versa. Both springs are wound the same way.
Let this thread die. The ones on the right are the fronts.
KillaB-
Suspension & Brakes
Jan 28, 2005 09:12 PM
airikkCRX
Apr 17, 2004 01:00 PM
PlikityPLAH
Sep 23, 2003 06:16 PM
BABY NSX
Sep 4, 2003 07:42 PM
VTEConly
35
Jul 22, 2003 08:49 AM
