Soft Brake
Old Apr 30, 2004 | 07:12 PM
ironballz's Avatar
Default Soft Brake
I have a 94' si and during very hot weather, my brakes get really soft.
While I'm sitting at stop lights, the brake will go softer and softer until the brake is depressed as far down as it can go.
I'm pretty sure this is heat related since it noly occurs when it's very hot out. What can I do?
Old Apr 30, 2004 | 07:14 PM
BauleyCivic's Avatar
Risky Business
Default Re: Soft Brake (ironballz)
Sounds like you need to bleed your brakes.
Old Apr 30, 2004 | 07:15 PM
TorganFM.'s Avatar
Default Re: Soft Brake (BauleyCivic)
Yes check your master cylinder for damage and bleed the brakes.
Old Apr 30, 2004 | 07:16 PM
-Gambit-'s Avatar
exactly change your brake fluid and bleed your brakes and you should be groovy.
Old Apr 30, 2004 | 07:45 PM
Lysawy's Avatar
Default Re: Soft Brake (Geeky_Gambit33)
what they said
Old Apr 30, 2004 | 07:52 PM
2lua's Avatar
check your booster.
Old Apr 30, 2004 | 08:23 PM
ironballz's Avatar
Default Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">check your booster.</TD></TR></TABLE>
I've already changed the brake fluid and bled the brakes...no diff...
I haven't however checked the master cylinder or booster...what exactly am I looking for though?
Old Apr 30, 2004 | 08:45 PM
TorganFM.'s Avatar
Default Re: (ironballz)
Leaks.. oil everywhere. Look around the brake pedal too. I don't know if it can leak around there but that's where my clutch master cylinder died and leaked.
Old Apr 30, 2004 | 08:57 PM
ironballz's Avatar
Default Re: (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">Leaks.. oil everywhere. Look around the brake pedal too. I don't know if it can leak around there but that's where my clutch master cylinder died and leaked.</TD></TR></TABLE>
Ok thanks alot!
Old Apr 30, 2004 | 10:17 PM
Ricey McRicerton's Avatar
You can check your booster very easily.
With the car off, pump the brakes until the pedal gets very firm. Now turn the car on and pump the brakes agian, if it's still very firm, then your booster is bad. If the pedal feels normal, your booster is fine.
EDIT: Sounds like fluid to me though. A leaky master cylinder would result in you always having a soft pedal.
Chev
14
Oct 20, 2017 03:32 PM
hteg12
Jul 18, 2013 05:13 PM
4DoorCivic1
Jun 4, 2012 08:43 PM
spintboy
17
Jan 3, 2008 08:49 AM
mingchi69
Jun 21, 2003 11:47 AM
