HF best for swap
Old Apr 30, 2004 | 05:02 PM
C-REX 88's Avatar
Default HF best for swap
Is it true that the HF crx is the best one to do a swap in. A kid with an si told me that he wanted my HF because of that.
Old Apr 30, 2004 | 05:05 PM
crxdriver89's Avatar
Default Re: HF best for swap (C-REX 88)
well, hf's are about 200 lbs lighter, and a lot of people would agree that its a great start
Old Apr 30, 2004 | 05:47 PM
d16singlecammer's Avatar
You could say an HF is the best CRX for swap because unlike the DX you wont have to worry about converting to MPFI, and over the Si its significantly lighter. Gotta love the 88s
Old Apr 30, 2004 | 08:40 PM
Rex_Dragon's Avatar
Default Re: HF best for swap (d15singlecammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15singlecammer &raquo;</TD></TR><TR><TD CLASS="quote">You could say an HF is the best CRX for swap because unlike the DX you wont have to worry about converting to MPFI, and over the Si its significantly lighter. Gotta love the 88s </TD></TR></TABLE>
I've had mine for 6 years now.
B20b block / B16 Head with ac : Its my daily driver.
Old Apr 30, 2004 | 09:22 PM
payneth's Avatar
Default Re: HF best for swap (Rex_Dragon)
would look alot better without those blueish white flames on the windows. but none the less a nice car.
Old May 2, 2004 | 07:51 PM
C-REX 88's Avatar
Ya thats the year i got iv'e had it for about a year but just started driving it. I just turned 16 and got my licence. I want to get the B16 swap. Does anybody know what the 1/4 is for them in vegas. The cars are slower here because of the elevation
Old May 2, 2004 | 07:52 PM
bardo's Avatar
your gonna have to change the spindles ill tell you that much..i got a b16 in my hf
Old May 2, 2004 | 07:54 PM
C-REX 88's Avatar
Car looks clean. I love the Si rims on EF's
Old May 2, 2004 | 07:56 PM
C-REX 88's Avatar
Default Re: HF best for swap (bardo)
What spindles should i get? 90-93 integra spindles?
Old May 2, 2004 | 09:31 PM
Harry_Randal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-REX 88 &raquo;</TD></TR><TR><TD CLASS="quote">What spindles should i get? 90-93 integra spindles?</TD></TR></TABLE>
That or Si CRX spindles...
Old May 3, 2004 | 01:16 AM
91b16acrx's Avatar
Default Re: HF best for swap (Harry_Randal)
i have a b16 in my hf had to change my hubs to da hubs, cant got worong with bigger brakes anyways, plus you have too, so you can run da axles
Old May 3, 2004 | 02:56 AM
bardo's Avatar
you could use the crx SI hubs, the 90-93 integra hubs, crx Dx hubs...you can even use 92-95 civic hubs..thats what i used..the only thing i had laying around
Old May 3, 2004 | 01:09 PM
pyro_freak8's Avatar
i've got a ZC in my 91 HF and i love it
Old May 3, 2004 | 02:44 PM
crx50's Avatar
Default Re: (pyro_freak8)
if you go with the 90 integra hubs and rear disk. Make sure you get the spider prop valve & the Master Cylinder & booster. It will stop on the dime. I did the same exact conversion I'm loving it.
Old May 3, 2004 | 02:51 PM
slowman's Avatar
I took way too long
Default Re: (crx50)
i have nothing wrong with the HF as a swap candidate, but Si pwns!
Old May 3, 2004 | 02:59 PM
out_of_order's Avatar
si got that summer moonroof....id say get the SI if its ur daily
Old May 3, 2004 | 08:36 PM
StorminMatt's Avatar
Default Re: (gotriceboy05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotriceboy05 &raquo;</TD></TR><TR><TD CLASS="quote">si got that summer moonroof....id say get the SI if its ur daily</TD></TR></TABLE>
Everybody uses this as THE reason why you MUST get the SI. But you really have to ask yourself how much you really want it. I, for instance, find no pleasure in letting the sun beat on myself on a hot summer day. I prefer A/C. In fact, I only opened the sunroof on my SI about two times during the entire time I had it. So if you think like me, you are better off with a low-trim CRX like the HF or DX. I would only get an SI if you consider the sunroof to be a 'must-have'.
Old May 4, 2004 | 04:01 AM
slowman's Avatar
I took way too long
Default Re: (StorminMatt)
my reason for getting the si was for the gauge cluster, seats, steering wheel, the engine, the front and rear sway bars, etc. and if you get a rex, it's got disc brakes all around. there are many advantages to the Si.
Old May 4, 2004 | 06:47 AM
crxY-49's Avatar
Default Re: (slowman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowman &raquo;</TD></TR><TR><TD CLASS="quote">my reason for getting the si was for the gauge cluster, seats, steering wheel, the engine, the front and rear sway bars, etc. and if you get a rex, it's got disc brakes all around. there are many advantages to the Si.</TD></TR></TABLE>
I agree...I love my si. The d16a6 is a sweet engine for turbo. I wouldn't ever want to spend a lot of money on a b-series then be slower than a turbo d-series.
But then again you can find the a6's for cheap as hell and swap on in a hf for minimal cost.
Old May 4, 2004 | 06:55 AM
SiRex91's Avatar
Default Re: (crxY-49)
My reason for getting the Si is the rear disk and sway bars I'm not really a big fan of the sunroof, but rear disk and sway bars kick ***
....Andrew who started with a 91 Si
Old May 4, 2004 | 07:21 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (SiRex91)
I looked around for a si for at least 2 years then I found one did all the swap stuff ect....... and I totalled it 2 months ago now I have a 88std model and I'm fu**ing loving it. I don't know what I was thinking getting that heavy *** pig to begin with. Oh yeah it has a sunroof who cares thats just more weight, blahh
Old May 4, 2004 | 08:56 PM
Project_ED8's Avatar
i started with an 88 hf...and now after buying\selling a couple ED's...i'm back to an 89 hf. for a swap...YES the HF is the way to go. keep in mind the 88-89 hf's weigh in at under 1900lbs. i think the 88 is 1819lbs and the 89 is 15 lbs heavier, weighing in at 1834lbs. now the 90-91's are in the 1900's.
Old May 5, 2004 | 04:35 AM
steronz's Avatar
Default Re: (Project_ED8)
I'm sure most of the weight savings in the HF comes from the lightweight motor. Once you drop a b series into it, put rear disks on, install some sway bars, and put decent seats/center console in it, the only weight difference between it and a swapped Si is gonna be like 20 pounds from the passenger side mirror and sunroof motor. Stock curb weights don't mean much once you start swapping.
Old May 5, 2004 | 04:59 AM
crxgator's Avatar
Default Re: (steronz)
i love my Si...
i dont have to swap anything over, it is perfect the way it is...plus the fact that i have a color that only came on 91 si's....
Old May 5, 2004 | 06:10 AM
T S R Performance's Avatar
Default Re: (crxgator)
Yeah pretty much all youre going t have to worry about is the spindles. Either use 90-93 Integra spindles, or 88-91 CRX Si or crx DX spindles. other than that, its just like a normal swap, its better than DX because you dont have to rewire for injectors
